Clutch Adjustment
Clutch Adjustment
vernier
Send a private message to vernier
Could someone tell me how to adjust the clutch on a no. 12 grader (oil clutch) ? I need to know how much free play between pressure plate fingers and throw out brg. and also sequence in clutch linkage adj. if any.
Vernier
Sun, May 6, 2007 6:21 PM
Thank you received: 93
Hi vernier,
here is OMI data for oil cluch adj., hope this helps. Sorry I do not have linkage adj. as it will be in the Serv. Man.
Sun, May 6, 2007 7:32 PM
vernier
Reply to edb:
Hi vernier,
Thanks edb for the info. sounds easy enough !! I recently got the engine back in the machine after new sleeves & pistons and electric start conversion, so far everything is working fine.
Thanks again!!
Vernier
Sun, May 6, 2007 9:09 PM
