close to calling the scrap man d7 3t
Showing 1 to 7 of 7 results
phillipstanley
Send a private message to phillipstanley
put water in radiator and went to crank would not run have fire new plugs new wires and i noticed a crack behind pony on pony and leak in radiator it looks i will be calling this tractor d7 3t jb weld caterpillar i need some prayers, money, help..... http://www.acmoc.org/bb/images/icons/sick.gif http://www.acmoc.org/bb/images/icons/sick.gif http://www.acmoc.org/bb/images/icons/doh.gif http://www.acmoc.org/bb/images/icons/confused.gif http://www.acmoc.org/bb/images/icons/yuck.gif http://www.acmoc.org/bb/images/icons/faint2.gif http://www.acmoc.org/bb/images/icons/mmph.gif http://www.acmoc.org/bb/images/icons/tsk.gif
Wed, Aug 17, 2011 12:23 PM
phillipstanley
I'm sorry Just get a little frustrated at times. Now I know how destructive water is in the cold.
PS Just want you to know I did not do it, I bought it that way and if I ever buy another, I will know what to look for. My Dad every winter winterized all his stuff. When I worked at the Ford dealer here in Sylacauga Ala. I would tell him the antifreeze should last for two or more years. But that did not stop him.
Thu, Aug 18, 2011 11:09 AM
phillipstanley
Reply to phillipstanley:
Pony block should last awhile now that it has a inch of jb weld around the back of it.
With the pony spining over choke on the engine backfires flame out of pipe and smoke out of carb. Hit and miss type and will even stop the starter from turning it over sometimes. choke off it just spins maybe a hit every once and a while? If change plug wires around nothing just spins.
how should i set my carburetor set screws you know like 1 1/2 turn or what top and bottom.
leak is not that bad in radiator so what would you recommend as far as stop leak.
by the way i never did move the magneto and if you touch the wire it will knock the fire out of you!!!!!!!! ouch
Please help, Thank you Phillip
Thu, Aug 18, 2011 11:43 AM
Skip in CT
Send a private message to Skip in CT
My poney loves the choke and will not run at all without it. There is also a fine line as to where the throttle and choke are positioned to keep it running. I played with the carb adjustments and it didn't make much differance so I use the choke.
Thu, Aug 18, 2011 6:18 PM
willitrun
Send a private message to willitrun
Reply to Skip in CT:
plug wires backwards?
Thu, Aug 18, 2011 9:26 PM
anyoldiron
Send a private message to anyoldiron
Reply to willitrun:
..................my pony is the same. needs about a 1/3 of choke to run smooth, currently taking the cowards way out as it starts up fine and is working so im leaving well alone 😉
lve been following your progress, youve gotta be closer to the finish than the beginning.......................historically speaking it seems when out of abject frustration thinking about petrol and matches gives me a warm and fluffy feeling im closer to getting the subject working than i think!! 😆
lts probably a no no on diesels, ive always found barsleak good for rads.
Keep the faith, best off luck.
Thu, Aug 18, 2011 9:58 PM
zootownjeepguy
Sounds like your Carburetor could use s GOOD cleaning. If the carb adjustments don't change the way it runs it means the passages and jets are plugged up.
Rich Salvaggio
D2 5U9917
Fri, Aug 19, 2011 5:18 AM
1939Cat
Send a private message to 1939Cat
Reply to zootownjeepguy:
Hollar before you decide to junk it. That pony might fit on my 39 d7. I live in North West Alabama too.
Mon, Aug 29, 2011 12:07 AM
