Choke and throttle Rod
Showing 1 to 6 of 6 results
Basdas
Send a private message to Basdas
Hello name is Bret have a 1958 7U42585. Working on the pony motor. I am looking for the choke rod first of all and a throttle rod that goes through the dashboard. On my tractor you start the pony motor from the tractor seat. Any leads or junkyards there any suggestions would be most appreciated. Thanks again Brett
Thu, Mar 24, 2022 7:00 AM
Hello and welcome! Those are going to be tough to find, not many in seat starters are around, may have to make them from scratch. The knobs are still available.
 [attachment=67199]Cat D4 Cont. 001.jpg[/attachment] [attachment=67199]Cat D4 Cont. 001.jpg[/attachment]
Thu, Mar 24, 2022 8:25 AM
Basdas
Thanks for the scoop and reply.
How many years did Cat use in seat starters?
Mines a 58 my friend has 56 and you start that from side of tractor.
Thu, Mar 24, 2022 10:59 AM
Reply to Basdas:
It was around late 57 on up, it was an option when ordering a tractor.
Thu, Mar 24, 2022 7:40 PM
Look to the 955 (12Axxxx) Traxcavator for parts. That's the origin of in seat starting for the D315 engine.
Thu, Mar 24, 2022 10:05 PM
Basdas
Thanks guys I really appreciate it since I’m new and green to the old Caterpillar tractors.
Thu, Mar 24, 2022 10:10 PM
Thank you received: 77
Reply to Basdas:
Can you post some pictures on your tractor of where the missing parts should sit
Fri, Mar 25, 2022 1:25 AM
