Chip on camshaft
Chip on camshaft
raklet
Send a private message to raklet
Pulled the camshaft out today and was dismayed to see a chip on it. There are two others with similar chips that are much smaller. I've included a pic of the worst one. There is no damage to any of the lifters nor can I even see scratching. Will the chip continue to grow? Can I use the cam as is? Can it be rebuilt? What does your experience have to say on the matter?
Fri, Sep 17, 2010 10:37 AM
Thank you received: 65
That looks more like spalling then chipping (failure of the surface heat treated metal). I would not use a cam with those conditions. Repair and regrind would most likely way exceed the cost of a good used replacement unit.
Fri, Sep 17, 2010 10:52 AM
smitrotterdam
Send a private message to smitrotterdam
Considering the location of the damage, at the point of highest loading, it does appear to be spalled. Unfortunately, it will only continue to spread. Are the other spalled areas at the same point on the lobes?
Sat, Sep 18, 2010 6:03 AM
raklet
Reply to smitrotterdam:
Yes, they are all at the same point and also on the same edge of the lobe (which I find interesting that it occurs on one side but not the other, but have no idea what it might mean).
Sat, Sep 18, 2010 9:34 AM
Reply to raklet:
Some cam lobe profiles are ground at a slight angle to rotate the lifter as it travels upward. Not sure if that's so on the D318 cam.
Sat, Sep 18, 2010 9:52 AM
