Checking Engine rpm on D6 9U
First Cat
Send a private message to First Cat
I would like to check the high and low idle rpm's. I have a digital tach and the tape to mark with for reading. How and where is the best place to do this and what kind of conversion would I need to use to figure. I know the service manual shows using a dial type tach at the hour meter .
Fri, Sep 7, 2018 8:41 AM
Can you get to the crankshaft front pulley relatively easy?
OR
How about opening the clutch cover on the floor board to access the driveshaft to the transmission?
Either place wouldn't require a math conversion.
Fri, Sep 7, 2018 6:31 PM
kracked1
Reply to drujinin:
OR
Front crank pulley will be just fine.
Fri, Sep 7, 2018 7:22 PM
Thank you received: 46
Reply to kracked1:
I have a old hand held Stewart Warner so I thought everybody did.lol My dad was not a mechanic or tool guy,but did custom harvesting back in the day when the customer was right.
If you read rpm at the hour meter it is half engine speed,on a Cat 318 as in the 9u D6.
Sat, Sep 8, 2018 2:26 AM
