checking after cooler leaks
earthgrader
Send a private message to earthgrader
how do you check a after cooler mainely on the water side, and if it is leaking what will it do ? if ti is leaking thanks
Sat, Feb 2, 2008 9:28 AM
pressurize the cooling system for leak checking, flow test for restriction/scale or perhaps there's a spec on charge air temperature.
depends on how bad the leak is and what configuration the cooler is (above or below the intake runners on the head). Real bad leak/slow leak over time, could bend a rod on startup if there's a cylinder with water in it.
Sat, Feb 2, 2008 1:09 PM
bob
Send a private message to bob
What engine is it on?
Later Bob
Sun, Feb 3, 2008 11:06 AM
MSTEC STEAMFEST
