Chapter 9 Caterpillar Twenty Two Electric Start Conversion
Showing 1 to 10 of 16 results
chugwater crawlers
Three Chapter 9 members worked together to convert a Caterpillar Twenty Two to electric start. It turned out great.
Look for a detailed article on this project in an upcoming issue of the ACMOC magazine.
[attachment=27233]Completed (1).jpg[/attachment][attachment=27234]Starter wiring (2).jpg[/attachment]
Mon, Jan 26, 2015 12:42 AM
old-iron-habit
Wow, Thats looks like a clean install. Nice shop also. I look forward to seeing the article.
Mon, Jan 26, 2015 1:06 AM
chugwater crawlers
Reply to old-iron-habit:
WyoCat did the install. He did a great job including relocating the choke. The nice shop is his. The photo below shows where I typically work on stuff. Outside! LOL.
[attachment=27235]cat22finishedwithnewseat2 (2).jpg[/attachment]
Mon, Jan 26, 2015 1:49 AM
Reply to chugwater crawlers:
Any idea what the Starter is that's installed?
Just in case I ever decided to do install one on mine.
Mon, Jan 26, 2015 5:34 AM
chugwater crawlers
Reply to drujinin:
It's a MPA #4162S. It also crosses to a Remy 25831 or a NAPA 2460674. It's off an IH Scout with a V8.
I have used the 4162S on my tractor. WyoCat got it to fit fine.
I bought the NAPA starter for another member to try and it is the same starter. We got it to line up on his tractor yesterday. We had to change out the spacer bolts because they were hitting the starter and it would not line up.
FYI. It's not a bolt in and it will not fit the factory ring gear. You will need to machine the flywheel for a ring gear and fabricate a spacer for the starter.
The magazine article explains it in detail with some photos to help you out.
Mon, Jan 26, 2015 6:47 AM
tailseat15
Send a private message to tailseat15
Looks like a repro farmall battery box, perhaps? I know, wait for the magazine.....
Tue, Jan 27, 2015 11:10 AM
Jeff M.
Reply to tailseat15:
That is great that is the kind of article We need in the magazine also restoration articles.
Tue, Jan 27, 2015 7:52 PM
chugwater crawlers
Reply to Jeff M.:
Tailseat, I think that is a Farmall battery box.
Thanks for the comments. I hope you guys will comment back and let me know if we hit the mark with the "how to.." article.
Wed, Jan 28, 2015 7:56 AM
chugwater crawlers
Attached are some more photos of the starter conversion project for anyone who does not get the magazine. I have included a photos of both brands of starters which are identical. I have also included a photo of the fabricated spacer required to get if to fit.
The tractor photo shows the location of the starter button and the choke lever. The knob next to the fuel control is the rerouted choke lever. You can see the starter button mounted next to the battery box.
The ring gear is NAPA # 600-3035. You will need to cut a lip on to the flywheel to get the ring gear to fit.
[attachment=28023]22starterconversionNAPA.jpg[/attachment][attachment=28023]22starterconversionNAPA.jpg[/attachment][attachment=28024]flywheelandringgear.jpg[/attachment][attachment=28025]Install completed (1).jpg[/attachment][attachment=28026]Cat22starter2.3MB.jpg[/attachment][attachment=28027]spacer.jpg[/attachment]
Sun, Mar 8, 2015 11:10 PM
rturn3060
Send a private message to rturn3060
where's THE GENERATOR ASSEMBLY???
Sun, Mar 8, 2015 11:53 PM
chugwater crawlers
Reply to rturn3060:
The tractor does have an original six volt generator mounted in the lower right front.
I do not have that hooked up to the battery. I use a trickle charger to charge up the battery. The battery is 12 volt.
You could make a bracket and mount an alternator. I've seen that done.
Eventually I plan to convert the 6 volt generator to 12 volt and hook it up mainly because I want to put lights back on it. The lights just need 12 volt bulbs. That's a whole other project.
Mon, Mar 9, 2015 1:36 AM
