C.B. Hay Bean harvesters PIC's
Showing 1 to 10 of 11 results
railforlife
Send a private message to railforlife
Here are some pics of bean theshers C.B. Hay and a few Price even an old Ventura
Thu, Dec 1, 2022 9:57 PM
gary in CA
Thank you received: 8
Thanks for the pictures.Brought back a lot of memories.We farmed about 1,200 acres of blackeyes and harvested them with a 1948 CB Hay with a 371 Jimmy
In the early years we put three four row Ventura planters together to make a 12 row planter.Sure wish I had some pictures of it.
We farmed rolling hills so we used sprinkler pipe for irrigation.Hand lines moved twice a day
Our tillage was all done with crawlers.Even pulled the harvester with a TD9 as wheel tractors then couldn't pull it up the hills.Sometimes if harvester was full it couldn't either.
One field we had was even steeper and sandy so we had to put our HD11 on it
Thu, Dec 1, 2022 11:44 PM
railforlife
Reply to gary in CA:
I am in the process of rebuilding my old pull type ventura planter into a 3 point setup. i have tries other planters but I always end up fixing that old Ventura and using it. it always gets a better germ rate and no dead spots than my john deer 71 setup.
Thu, Dec 1, 2022 11:48 PM
Thank you received: 269
Awesome photos. Thank you for sharing. Is the smaller one called the Junior? BIG BERTHA seemed to be the choice for many here in the Sutter Basin.
These photos have inspired me. Crockpot is coming out for some baby Limas, sliced linguisa, pork hocks, onion, garlic and tomato! JM
Thu, Dec 1, 2022 11:56 PM
railforlife
I have that exact harvester with a 471 on it sitting in lompoc. I cant afford to get it hauled all the way up here so I am buying another one closer. that 48 standard is in my opinion better than the Bertha, not as tall and easier to maneuver.
Thu, Dec 1, 2022 11:57 PM
railforlife
The smaller one is my 36, it was a 2 cylinder with the thresher on the opposite side as the newer machines it had a crossover belt that dumped the beans on top of a counter rotating set of choppers before the first cylindeer. it had an old 3 speed transmission you used to speed up or slow down the cylinders. it worked great but it finally had too many problems to fix and was cheaper to get another unit.
Fri, Dec 2, 2022 12:01 AM
17AFarmer
Reply to railforlife:
Railforlife. While I agree the 48 standard are nice machines. The Big. Bertha solved some problems that the standards had, one was getting to the cylinders. Digging it out if it plugged! , I liked the straw rack and sand screen drive much better. better balanced , I liked having the shoe on the rear of the machine and not having the cross auger and the elevator to have to take it to the top shoe, I put 7 inch auger and speeded the elevator up to stop the plugging . The 18 bar front cylinder is nice! Plus they are a little wider. We had Cat 3160 engine and finally had to put in 2 7/16 shafts in the front cylinders to hold the power plus heavier cutter shafts. The 48 was a Good machine but could never equal a Bertha, as far as moving them the length and width is close to the same I could not see any difference, in California the Biggest DOG wins out and you have to drive accordingly even though you don’t like too. California drivers are not kind to people moving equipment as I said I took my half out of the middle if had too. IF enough beans were still being grown I would absolutely still be running a Machine the best times of my life I DO miss it . 17afarmer. Mike
Fri, Dec 2, 2022 1:30 AM
railforlife
Reply to 17AFarmer:
I just know when I move a newer Bertha with the dump bin, I have to remove the elevator to the cleaner or it is way over height even for the lowest of lowbeds, and the standards can go on a 18 1/2 "  deck height lowbed without taking anything apart. I have both and I like them both for different reasons, but I am hauling a standard up to my farm in Mendocino county so I dont have to mess with any disassembly. Plus one can almost get a standard given to them where a Bertha is still going for anywhere from 25k on up. I just gave a 47 standard to a friend to harvest beans in a remote location so he can leave it there and keep him from the hassle of taking his bertha out there. I think even a standard compared to anything else out on the market today is still far superior but I agree the Bertha was the best design. Ole Colin had a great idea never needed changing in 75 years. I wish Melo would reproduce some of them even a jr would be nice for a small operation.
Fri, Dec 2, 2022 2:51 AM
17AFarmer
I never saw very many get hauled on a lowboy they tow pretty nice behind a truck
Fri, Dec 2, 2022 6:54 AM
gary in CA
Reply to 17AFarmer:
Reminds me of the time a friend pulled his bean harvester from Newman Ca to San Jose Ca by the airport.On 580 the harvester blew a tire.The CHP stopped to check on them and he asked the CHP to help them pull back on the freeway.The CHP laughed and told them you are bigger than them they will move over.
Fri, Dec 2, 2022 7:23 AM
17AFarmer
Probably the funnest thing I had happen in the 70s, I left home with a 3 cylinder behind a bobtail truck, I had a very nice guy with me. I went a little way and a brand new Chevy gets behind me driven by a couple of young guys, I guess I was dusting them a little and I had to go a ways before I could pull over. Somehow they got around me and stoped not very far in front of me I did get it stopped in time thank god I didn’t hit them, they got out of the car and came back to us and said we’re going to whip both of your a————es for dusting us!!!! My helper was ahead of me and grabbed a piece of pipe we used to knock tires and told the boys go for it but I am going plant this pipe across one of your heads!! He knew how to fight it would not have been pretty! They got in their car and left we went about our way You just never know what you will get into! 17afarmer. Mike
Fri, Dec 2, 2022 8:06 AM
