caterpillar twenty-two sprocket removal
Showing 1 to 7 of 7 results
Orchard22
Send a private message to Orchard22
Hi, y'all!
I am about to remove, and swap my 22's sprockets for some better ones, and I have some questions.How much force is needed to remove the sprockets? Can you safely heat, or do you have to heat the sprockets to remove them? Are the sprockets made out of cast-iron or cast-steel? any info. is greatly appreciated!
1935 Caterpillar
Twenty-Two Citrus(or low top seat orchard)
serial number:2F2204
Fri, Dec 31, 2010 10:48 AM
JasonPayneCrawlers
when I restored my wide ten I had to heat and beat and I mean beat. I thought that I was going to break but after trying all other options beating them was the only way I could get them off👍 I was worried that I would mess up the bellows seal but they were okay
Fri, Dec 31, 2010 10:56 AM
Reply to JasonPayneCrawlers:
I use a similar to attached photo Gear puller except its rated at 10 ton. Mine is an older 2 and 3 leg style. I'm trying to show you the wings where you beat on it in the attached photo. You attach it and beat on the wings of the puller with a 6 pound hammer. I have had good luck with this tool and heating the casting around the shaft to expand the sprocket hub away from the shaft. I have used this on D-2 and 22 steering clutches and brake drums also.
Jeff
Fri, Dec 31, 2010 7:32 PM
rustrunner
Send a private message to rustrunner
Reply to drujinin:
Jeff
My brother started to remove the sprocket on his 22 several years ago. We heat, beat, used pullers, - nada. Did all of the above several times with no luck, so he decided to just remove the nut and run it until the sprocket came off. Well that was 8-10 years ago, and he has farmed with the tractor, we have run it at shows, logged with it, and NADA. Not sure if that sprocket will ever come off.
Fri, Dec 31, 2010 9:11 PM
Arthropod
Send a private message to Arthropod
Reply to rustrunner:
Be careful removing sprockets. I have removed several from D2's. Same as the 22. I use an OTC 17 1/2 ton push/puller like this one:
http://www.amazon.com/OTC-938-17-1-Push-Puller/dp/B0002SRH8I
I had to also purchase adapters so I could screw into the sprocket's puller holes near the center of the sprocket.
The method I used successfully-
1. Take a spare large sprocket cap nut and grind the center off, so you have an open nut. Thread this nut onto the sprocket shaft, but leave it a little loose. The purpose of the nut is to keep the sprocket from flying off and killing you or anyone watching you.
2. Attach the push/puller, using adapters so that the two pull shafts are attached to the threaded sprocket holes and the center puller shaft rest on the center sprocket drive shaft.
3. tighten the puller as tight as you can get it. The sprocket probably won't come loose. You are starting to worry that the puller is going to explode or something.
4. Leave the puller attached and tight, then heat all around the sprocket near the drive shaft.
5. Take a 10 pound or so sledge and whack the outer rim of the sprocket. The sprocket should pop loose violently. The modified cap nut will keep the sprocket from flying off.
6. Now the sprocket is loose. Just unscrew the cap nut and slip the sprocket off.
The new sprocket is suppose to be pressed into place. I never had a way to do this, so I just would tighten the cap nut while hitting the sprocket with a sledge. It seemed to get the sprocket tight. If you don't get the sprocket tight, and the sprocket moves, the splines on the drive shaft will become damaged.
Good luck, take your time and be careful.
Sat, Jan 1, 2011 9:00 AM
ejensen
Send a private message to ejensen
Reply to Arthropod:
[quote="Arthropod"]Be careful removing sprockets. I have removed several from D2's. Same as the 22. I use an OTC 17 1/2 ton push/puller like this one:
Good luck, take your time and be careful.[/quote]
What is the thread size of the holes in the sprocket? What type of adapters and where did you purchase them to attach to the legs of the puller? Thank You,
email: [email protected]
Fri, Mar 25, 2011 11:57 PM
Catmatt
Send a private message to Catmatt
Reply to ejensen:
Grainger is where i purchased our puller to remove the sprocket. Once you get a lot of tension on the sprocket with the puller, hit the puller with the sledge and then tighten. repeat. Be careful when it breaks loose it will go flying...make sure you have the nut on loosely to prevent that. I would also apply a lot of heat. If you are still having problems just cut the sprocket off with a torch. You did say you are replacing them because they are trashed????
Sat, Mar 26, 2011 3:45 AM
ejensen
Reply to ejensen:
[quote="ejensen"]
email: [email protected][/quote]
The puller holes in the sprocket on my D2 are 5/8 NC. I'm the shanot sure of the thread size of the shaft that the nut attaches to secure the sprocket. Looks like pipe thread.
Wed, Mar 30, 2011 7:33 PM
