caterpillar twenty clutch
Showing 1 to 6 of 6 results
growlyone
Send a private message to growlyone
Is there anyway to adjust clutch brake
Brake and collar aren't making contact
I gotta be missing something
Wed, Apr 8, 2020 8:01 PM
bruce oz
Thank you received: 21
from operator book 8c1 up , you didnt say serial number/ model L- PL- 0R 8C ,
Thu, Apr 9, 2020 3:19 AM
growlyone
Reply to bruce oz:
s.n. pl 5190
How do i adjust clutch brake or is there not any adjustment to it.
it looks like when you adjust clutch every thing that makes brake work also goes with it.
farther away from brake lining as lining is bolted to transmission shaft.
I have replaced lining on clutch which was not wore much.
Lining on brake looks good but anybody have a thickness measurement.
It is a hand clutch operated machine
Growlyone
Thu, Apr 9, 2020 5:50 PM
Skinner
Reply to growlyone:
s.n. pl 5190
Growlyone
[quote="growlyone"]s.n. pl 5190
Growlyone[/quote]
Look for another hole where it’s bolted on the shaft that puts the brake pad slightly closer should have a few holes
Thu, Apr 9, 2020 9:08 PM
Reply to growlyone:
s.n. pl 5190
Growlyone
Growlyone[/quote]If the twenty is like the twenty-two, there are three sets of holes on the clutch brake housing to allow for adjustment of the brake. Just remove the capscrew, index to the next hole, which brings the brake lining forward, then replace the capscrew. See example from my twenty-two. Ray
[attachment=58123]DSC_0100.jpg[/attachment]
Sat, Apr 11, 2020 6:38 AM
Thank you received: 22
Doesn't look like PL1590 has that feature?
Sat, Apr 11, 2020 7:09 AM
bruce oz
http://www.acmoc.org/bb/showthread.php?33420-Twenty-won%92t-go-in-gear
Sat, Apr 11, 2020 11:03 AM
