Caterpillar S-D8lgp Big Foot
Showing 1 to 10 of 15 results
QuAD
Again found a Caterpillar S-D8lgp and it is also for sale in Washington state.
This has a Cat D9 engine.
It is not known whether this machine was used at the South Pole or in Greenland.
Thu, Jan 25, 2018 6:37 PM
janmeermans
Quad,
Thank you for posting. The blade on this one is different from the rest I have seen (mostly in pictures). It does not look like the air filters are all there, pieces missing? Original Pony tank is gone. Also no drawbar hitch.
Not sure how this would work doing forestry work with the wide pads mixing it up with stumps and logs. Pads look good considering that.
JanM
Thu, Jan 25, 2018 9:06 PM
7upuller
Reply to janmeermans:
Quad,
JanM
Hey Jan,
They did a good job changing the Cutting Edges when needed! :eek2:
Thu, Jan 25, 2018 10:37 PM
Thank you received: 16
Reply to 7upuller:
Hey Jan,
The green algae and one of those unsatisfactory exhaust pipe flappers doesn't augur well for its condition. Still, it's probably easier to fix than the one that's in the crevasse : )
Thu, Jan 25, 2018 10:57 PM
Reply to 7upuller:
Hey Jan,
[quote="7upuller"]Hey Jan,
They did a good job changing the Cutting Edges when needed! :eek2:[/quote]
Ha! i was going to say wow, that cutting edge looks superb! lol
Thu, Jan 25, 2018 11:14 PM
jstandle
Send a private message to jstandle
That would be a cool addition to the Antique Powerland museum in Brooks.
Jordan
Fri, Jan 26, 2018 12:22 AM
QuAD
Reply to jstandle:
Jordan
Yes it run
No its not coming over to the Netherlands
Fri, Jan 26, 2018 12:50 AM
TimT
Send a private message to TimT
Reply to QuAD:
Yes it run
My bet its use was in settling pond clean out or something like that.
Fri, Jan 26, 2018 1:14 AM
Thank you received: 19
Reply to TimT:
Hi, Folks.
ANOTHER one????????????? Damn, these things are breeding like rabbits. LOL.
I'd like to know the origin of that blade. That style of 'sway brace' built onto the front end of the push arms looks like some LeTourneau blades I've seen.
Hi, Quad.
Thanks for posting these photos, M8. Evidence of another one.
Does anybody have any updated information on the one(s) allegedly 'resting' up in Alaska that had a D353 engine and orange paint work?
[attachment=46731]Cat D8 14A stretched ex-U.S. Army with D353 engine_1A_Acmoc.jpg[/attachment][attachment=46732]Cat D8 14A stretched ex-U.S. Army with D353 engine_1G_Acmoc.jpg[/attachment][attachment=46733]Cat D8 14A stretched ex-U.S. Army with D353 engine_1D_Acmoc.jpg[/attachment]
I also have a photo of the front-mounted long range fuel tank for the tractor.
[attachment=46734]Cat D8 14A stretched ex-U.S. Army with D353 engine nose tank_1F_Acmoc.jpg[/attachment]
Fri, Jan 26, 2018 4:54 AM
7upuller
Hi, Folks.
Hi, Quad.
Deas,
I think Larry Cruz (owner of Pam) ended up with that one. He is planning rescue operations, last I talked with him.
Glen
Fri, Jan 26, 2018 6:17 AM
Reply to 7upuller:
Deas,
Glen
Hi, Glen.
Here's hopin'. It would be good to see it go to a good home instead of being left out there in the bush to simply melt away in iron oxide.
Fri, Jan 26, 2018 6:46 AM
Chapter 2 The Link Club's AGM
