Caterpillar No.1 / No.4 part numbers needed
Showing 1 to 10 of 14 results
truckun95
Send a private message to truckun95
I am looking for a few part numbers on a No.1 Terracer or No. 4 Hi-Way Patrol. I have been unable to locate the part numbers from the later Preco parts books as the parts had been updated and changed from bolt on to welded. Looking for the part number(s) of the lower pivot on the mold board blade. Picture attached shows the later style welded mounts noted in parts book, and the other the bolted / riveted bracket. Any help would be great!
Thank you,
Ryan
Wed, Apr 12, 2017 12:06 PM
brewzer
I have the early book. I will check the part numbers .
Wed, Apr 12, 2017 12:09 PM
truckun95
Reply to brewzer:
Thank you Brewzer!
Wed, Apr 12, 2017 12:32 PM
Rodten
Reply to truckun95:
Thank you Brewzer!
I have the full parts book line on the #4 Hi Way Patrol at home I will take a look. What is the serial # of yours. Come on down to Carlinville, Il Memorial weekend (Saturday and Sunday) for the Macoupin Co. Historical Societies Fall Festival. If all works out I will have my Hy-Way Patrol (with terraceing wheels) out there with my 22.
Thu, Apr 13, 2017 2:07 AM
brewzer
Reply to Rodten:
Pivot bracket - 1D5624 for the 8, 10 and 12 foot. 1D6131 for the 6 and 7 foot. I tried to take pictures of the page but my camera was not good enough for them to be clear. I couldn't scan them without ruining the book.
Thu, Apr 13, 2017 4:17 AM
truckun95
Reply to Rodten:
Sadly the serial number plate is no longer on the unit. I will put it on my schedule for Memorial Day weekend maybe stop on by!
Thu, Apr 13, 2017 6:12 AM
truckun95
Reply to brewzer:
Thank you Brewzer I will look into those numbers you provided! Appreciate the help
Thu, Apr 13, 2017 6:13 AM
brewzer
Reply to truckun95:
I checked my grader (#4 Highway Patrol) and there were no numbers on the pivot brackets. There were numbers on some of the other brackets .
Thu, Apr 13, 2017 7:54 AM
Rodten
Reply to brewzer:
Truckun95,
Brewzer gets points on this one. The numbers he gives are in both my Caterpillar parts books. The first one (form P-1554) is effective 3D1 to 3D200, the second (form 5522) is effective with 3D201 with no end effective number. The Preco No. 4 Hi-Way Patrol book (form 30122) is effective 3D1301-up. Not sure if another book should be in this list or not. The Preco book does have a different pivot bracket shown as your post shows. Hope this helps or adds to the mystery.
Rodten
Thu, Apr 13, 2017 9:56 AM
Rodten
Reply to Rodten:
Truckun95,
Rodten
Doing a quick look between these three books I see that the major change between the Caterpillar books and the Preco book is that the rear axle is not adjustable side to side on the Preco as it is on the Caterpillars. The square part on the rear axle on the Preco is 45 degrees of that on the Caterpillar without the cogs welded to it. ALS to note the Preco book is the first to show the terracing style disk wheels, though mine is serial # 3D1048 with a Caterpillar tag and has this style wheel. Not knowing the history of my machine I dk not knownif I came from factory this way or was a later change over. I purchased mine at an Aumann thanksgiving auction when they where at the fairgrounds in Taylorville, Il (along with my 22, they where a trailer full together). Thought I would throw this out there to make ya all go hummmmmm.
Thu, Apr 13, 2017 10:23 AM
truckun95
Reply to Rodten:
Truckun95,
Rodten
[quote="Rodten"]Truckun95,
Rodten[/quote]
Thank you Rod,
Certainly helps, on early models the pivots were riveted on and later welded. I was not aware of the rear axle. I can not remember but if I remember right the terracer did not have the movable rear axle, instead it was a fixed axle. The Hi-Way Patrol grader had a adjustable rear axle.
Rod does yourshe have two identification plates on the left side? Possibly one larger one and a smaller one for the serial number? I believe the identification plates varied over time and from manufactures.
Thank you
Thu, Apr 13, 2017 1:14 PM
