caterpillar locomotive
Showing 1 to 10 of 13 results
acat65
Send a private message to acat65
I was talking to a r.r. engineer saturday and ask about his experience with the cat loco's.He is not happy with them,he say's the vibrate and shakeand not a pleasure to run, I know this does'nt pertain to what most of us play with,but it's like someone bad mouthing your family,He is a good friend did not mean it personaly,but most of would expect the best out of Cat. just my two cents Gene
Tue, Oct 7, 2014 6:35 AM
old-iron-habit
Interesting comment. Just curious. Are these Cat engines another engine option in a existing series of locomotives or is it an all new locomotive series. I wonder if its all engine vibratation and shake or if there is other factors telegraphing through.
Tue, Oct 7, 2014 6:54 AM
Reply to old-iron-habit:
I wonder if it is an older EMD Chassis? Big Slow speed engines have a different vibration than a smaller 3500 series turning higher RPMs. A lot of work has gone into newer rail engines to isolate the engineer cockpit/cab from the rest of the engine. Not sure where EMD was in this process?
Tue, Oct 7, 2014 7:56 AM
BobPV15
Send a private message to BobPV15
Reply to drujinin:
I would think the vibrations are coming from something other than the engine. Any engine of 6 cylinders or more can be and are internally balanced. Do you know which locomotive he was referring to with those comments?
Tue, Oct 7, 2014 8:39 AM
That's a pretty loose statement!!!! What engine/vintage is being referred to?
Tue, Oct 7, 2014 9:03 AM
spike
Send a private message to spike
Aloha in 1973-74 i was employed as a motorman in the Henderson west tunnel project in Colorado we had as yard locomotives 2 15 ton cat powered diesel locomotives im not sure of the size big 6 cylinder jobs.On the run up the dump pushing 13 heavy muck cars the exaust side of the turbo would glow orange hot . We would set the throttle wide open in 3 gear & open the door to engine & get close to that hot turbo to stay warm as it was often 20 - 30 below 0 lol the good days.
Tue, Oct 7, 2014 10:08 AM
mog5858
Reply to spike:
can't find it but i think cat has there own line of loco i remeber seeing something at conx or maby it was from a mine expo that a friend went too it was all done up cat. but i have bean wrong before and i be i will be wrong some time soon
Wed, Oct 8, 2014 6:29 AM
acat65
Reply to mog5858:
I didn't find out the combination, they were running,or the rail line he works with ,he live at Hoopstan,Il and I'm guessing he may work out of Danville,Il. I won't see him anytime soon s mabee someone else will have some ideas. Gene
Wed, Oct 8, 2014 7:12 AM
ronm
Reply to acat65:
Cat has owned EMD since about 2010, bought them from Berkshire Hathaway (Warren Buffet) as I remember...GM spun EMD off several years before that.
Wed, Oct 8, 2014 9:20 PM
Claney
Send a private message to Claney
Reply to ronm:
I ran a Cat powered loco back in the 80s I think it was. Cat installed engines in three locomotives. they were the GP ( jeep ) type with 6 axles. They ran
a lot smoother than the old emd's and a lot less noise. I worked for ATSF and they were running them from Chi to Barstow or San Bern. It wasn't long
before they disappeared. Don't know what happened to them. They were either 12 or 16 cylinder. Probably 12. Seems like they always came thru Amarillo
at night so couldn't see too much.
Claney
Thu, Oct 9, 2014 9:27 AM
ronm
Reply to Claney:
Claney
I know the UP has some Cat-powered locos. My friend that works at the Cathouse here used to go to the railroad yard to do tune-ups on, I believe, 3516's in locos...he was kind of a 3512 & 16 specialist, the oil patch has a bunch of them...
He has since graduated to service advisor, so no more big engine stories...but he does have an unusual piece of yard art-a 3516 crankshaft...
Thu, Oct 9, 2014 9:26 PM
