Caterpillar hydrolic Pipe
cheshire cat
Send a private message to cheshire cat
Just had a hose let go on a 44/2S blade on my 5u d2 can you still get the same OD to work with the clamps ???
Tue, Nov 29, 2016 5:40 AM
oldbeek
Cat hose is higher rated and more braids of wire that Aeriquip or Parker. Cat hose has a larger od than generic brands. Ck with your Cat dealer
Tue, Nov 29, 2016 6:37 AM
Thank you received: 65
Reply to oldbeek:
That would be a 1-wire hose application. SAE100R1 specification.
Check dimensions of your old hose. 3/4" id x 1.10" od.
Cat equivalent would be #716 specification. Same dimensions but the Cat hose exceeds SAE spec for impulse cycles.
Wed, Nov 30, 2016 12:53 AM
cheshire cat
Thanks I will go and see the guys at Finnings ...
Wed, Nov 30, 2016 3:03 AM
