Caterpillar Engine Oil
Showing 1 to 10 of 32 results
Daytonengines
Send a private message to Daytonengines
Could anyone tell me what would be the best engine oil for a D-318 and a D-13000. Also what is the best engine oil and weight for pony motors. Thank you. Dave
Sat, Jun 23, 2018 8:56 PM
Theres many suggestions used out there but i am using Kendall 15-40 for older engines and Pennzoil 30W for gas engines [starting engines]. A straight 30W diesel engine oil is preferred also for the old engines.
Sat, Jun 23, 2018 9:12 PM
WA7OPY
Send a private message to WA7OPY
Trick question, no one will agree....I use 30 wt in everything....WA7OPY
Sat, Jun 23, 2018 10:02 PM
greengiant
Send a private message to greengiant
I always enjoy these oil discussions.
The Cat mechanic who delivered my 17A checked the pony level before starting it and discovered that the "oil" was some kind of milky whitish gunk. don't know if the previous owner had used the kill switch rather than turning off the gas or what it was all about, but it was satisfying to drain it out yesterday, run a little diesel through, and fill with fresh oil.
Sat, Jun 23, 2018 10:11 PM
TOGNOT
Reply to greengiant:
You will then have about 4 days of material to read. It IS interesting. :amen:
Sat, Jun 23, 2018 10:30 PM
Dozer Doug
Send a private message to Dozer Doug
Reply to TOGNOT:
Rotella heavy duty 30w. In both diesel and pony.
Sat, Jun 23, 2018 11:46 PM
Reply to Dozer Doug:
Golly, I'm gettin all confuzzed now.
[attachment=49491]Gomer4.jpg[/attachment]
Sat, Jun 23, 2018 11:51 PM
Rome--I like your captions!!! I use Kendal series 3 30 wt in diesel and 30 or 40wt non detergent in pony of any brand
Sun, Jun 24, 2018 12:07 AM
Reply to dpendzic:
Thanks, need a little humor once in awhile.
Sun, Jun 24, 2018 1:15 AM
Delo400 15W40 ....NOT the LE formulation that is for the engines with diesel particulate filters. I need to see some data that shows how the new oils perform in old engines with flat tappet lifters before I will use them.
Sun, Jun 24, 2018 3:18 AM
TOGNOT
Ccjersey, I did post a study about a year ago that dug into just that topic. Written by an oil engineer who was also a corvair enthusiast. ( corvairs have flat tap pets it seems). My take away from his study was : is not an issue. But if you search my posts you can get Ed Jew kated on it like me !
Sun, Jun 24, 2018 4:10 AM
