Caterpillar engine internal paint
Showing 1 to 6 of 6 results
Justinc
Send a private message to Justinc
Hi guys just wondering if anyone knows what the ceramic colour coating is in the engine internals as i had my block acid dipped and the paint has come off is this a problem or will it be okay without it?
Sun, Jun 26, 2016 6:47 PM
Google up "glyptal paint" and you can read all you want on it.
Sun, Jun 26, 2016 7:36 PM
Thank you received: 63
I read a quick article by some hot rod enthusiasts and the consensus was it's not worth it, especially for used block where there are greater adhesion problems. Of course your mileage may vary : )
http://www.jalopyjournal.com/forum/threads/is-glyptal-engine-paint-worth-the-bother.644312/
Sun, Jun 26, 2016 9:13 PM
Just use Cat yellow primer.
Sun, Jun 26, 2016 9:21 PM
Mike Mahler
Send a private message to Mike Mahler
I use red insulating varnish on the insides of the engines I rebuild. It dries nice and hard and stands up to oils well and doesn't wash out when parts are run through a hot tank. This is the same stuff that is found on electric motors to seal the windings.
Mike
My services shown at www.myspace.com/vintageengine
Mon, Jun 27, 2016 12:04 AM
Justinc
Reply to Mike Mahler:
Mike
Thanks guys for your input my only real concerns is rust when the machine sits for a few months but i guess oil on the insides might prevent that from happening
Mon, Jun 27, 2016 3:59 AM
Thank you received: 34
Reply to Justinc:
Hi Justin,
at The Dealer we tried to buy some way back when and could not source it local.
It is primarily used to seal in any missed casting sand and seal up any small porous areas of casting.
We never bothered as we reckoned after the hot tank and steam clean that the sand would be gone and the outer paint would seal the casting--never recall any feed back of weeping castings in 40 odd years.
I think GM did some tests and decided not to continue with its use years ago.
Mon, Jun 27, 2016 7:27 AM
