Caterpillar engine, but for what?
Showing 1 to 10 of 19 results
cable control
Send a private message to cable control
To the brains trust.   Located in a shed in Central Queensland, a Cat engine with the serial number 5E5990.   What is it out of, or is this a non captive engine?
Wed, Feb 1, 2023 8:51 AM
josh
Thank you received: 10
5E5501 to 5E6000 are listed as Miscellaneous Engines, maybe a picture or some casting numbers will help.
Wed, Feb 1, 2023 8:57 AM
Texas3T
Send a private message to Texas3T
Reply to josh:
5E prefix should be an early D8800 power unit diesel
Wed, Feb 1, 2023 9:15 AM
bruce oz
Thank you received: 21
Reply to Texas3T:
5E5990 is a D6600 power unit
Thu, Feb 2, 2023 9:44 AM
cable control
Reply to bruce oz:
I had a brief look at it some years back when I picked up a Twenty from the same man.   Is it a six cylinder with two heads, or is my memory playing tricks?
Thu, Feb 2, 2023 2:56 PM
Reply to cable control:
5E would be an early RD-8 engine, six cyl. D11000 model.
Thu, Feb 2, 2023 8:55 PM
Thank you received: 41
Judging by the laundry list of engines this prefix is assigned to, Josh's "miscellaneous engines" sounds like a good description. I think 5E was also assigned to a tractor if I'm not mistaken?
Thu, Feb 2, 2023 8:59 PM
naylorbros
 [attachment=70942]IMG_4214.JPG[/attachment] Here is the list for the 5E prefix out of my old NPR
Thu, Feb 2, 2023 9:14 PM
Davross22
Send a private message to Davross22
Reply to naylorbros:
The next move is to check it out and do an appraisal. Let me know CC and we may travel together. Here's hoping someone has a picture of an original.
Fri, Feb 3, 2023 10:16 AM
cable control
Photos of 5e mystery engine.   We THINK that the engine may have been fitted to a grader built in Australia under licence to Caterpillar by Steelweld.
Thu, Mar 16, 2023 4:11 AM
cable control
Photos of 5E engine in question.   We THINK it may be from a grader, built in Australia by Steelweld, under licence to Caterpillar.   I know several machines or impliments were built under licence in Australia and New Zealand.    Still not 100% sure!
Thu, Mar 16, 2023 4:13 AM
