Caterpillar Dozers fighting CA fires
Showing 1 to 10 of 12 results
pbamburak
Send a private message to pbamburak
This article was in the September 10, 2020 Wall Street Journal and discusses the role of Cat dozers and experienced operators fighting the current California wildfires.
Sat, Sep 12, 2020 11:06 PM
gauntjoh
Librarian
Thank you received: 5
Hi, Did you mean to include a link within your post ?
Sun, Sep 13, 2020 1:20 AM
Reply to gauntjoh:
Click the image box below the post
Sun, Sep 13, 2020 1:27 AM
Djmayer
Send a private message to Djmayer
Yep
Dozers are key to fighting wildfires. Cal fire fire stats include # dozers right with helicopters and fire crews.
Sun, Sep 13, 2020 2:04 AM
Thank you received: 140
Reply to Djmayer:
Yep
Hi, Folks.
Thank you, pbamburak, for the link to the article.
Dependent on the situation, there are several earth moving machines that can make a big difference pretty quickly. While crawler dozers pretty much have a monopoly on wildfires in rough country, I have used both graders and an elevating scraper to very good effect on grass fires in open fields.
The elevating scraper, a Cat 633D, was spectacular. It was fitted with teeth on the middle section of the cutting edge. The bowl floor was left fairly wide open, the elevator was running and the machine straddled the edge of the fire, gobbling up dirt and burning grass, scrambling it all up and dumping it out behind the cutting edge at about 2 - 2 1/2 miles per hour. The fire was caught early and "mission accomplished" in about 15 minutes.
I take my hat - or rather my Cat cap - off to the people operating dozers in wildfires here in California and up in Oregon 'cos they perform their miracles in some pretty rugged country at times.
Just my 0.02
Sun, Sep 13, 2020 11:26 AM
Hi, Folks.
Just my 0.02
I'm surprised they dont use offset disks for the grass areas, they would cover so much more ground and be allot faster than a narrow dozer blade.
Sun, Sep 13, 2020 9:15 PM
Hi, ROME K/G.
When there is already a fire, you use what you have at the time to the best of its and your ability. If there is a dozer working in the same field, would you go looking for a tractor and disks? When you have a Cat 633D scraper working on a road right next to the field that is on fire, would YOU go looking for a tractor and disks? Ditto with a grader working right alongside that field?
It also takes a fairly big tractor and set of disks to cut wider than a D6 dozer - or a grader - or a 633 scraper.
Several times now, I have had grass fires out before the fire brigade arrived using what was at hand.
Mon, Sep 14, 2020 1:09 AM
Hi, ROME K/G.
Some fires are not even close to the areas where the fire is heading and nothing is done! They [the property owners or who else] could have those areas taken care of. but what ever, there's always the experts out there and by the time they figure it out its to late anyway. Fire prevention is the key, but everybody waits until it happens, so deal with it!
Mon, Sep 14, 2020 3:21 AM
oldbeek
On a fire near me they were working on slopes up to 45 degrees at night with helicopters with spotlights guiding them. No place for a disc. They used to only use straight blades. Worried about burned hoses. Now they use angle blades. Straight blades were much slower on most fires..
Mon, Sep 14, 2020 1:10 PM
Reply to oldbeek:
Hi, Oldbeek.
I can understand why they would choose to use angle blades - the grader advantage of getting rid of the cut material to the side while still cutting more combined with the dozer advantage of handling rougher terrain without risk of punctures.
Mon, Sep 14, 2020 1:20 PM
Thank you received: 62
Hi, Oldbeek.
To many places where a disc is of no help. I have a 100 hours pulling a disc to every hour I have running a dozer. A dozer will makes a fire line anyplace you can drive it.Much of the clay dries to concrete and it is dry when the fires are at there worst. So even a heavy 12 inch spaced disc would not cut a clean line like a dozer. Generally speaking Cal Fire does a great job in areas where a disc would be a good tool already. The chaparral brush type country or forest land is where they struggle. If they can get there in the first 15 to 20 minutes 2 or 3 loads of retardant air dropped and its about out. But once it gets beyond 100 acres and you have terrain where a dozer cannot operate look out. And a lot of this state limits where a dozer can go.
Back in 16 I was on the main road to a 100,000 acre fire about 3 or 4 miles away.The only public owned dozer bigger than a D6 where some D8K's from Kern county. Which of course are needed in the Sierra Nevada and the big trees. I cannot recall seeing Cal Fire with anything but D6 and angle blades since the 90's. In the old days they did have some IH TD 9's and AC HD 6's but not since the 80's.
Tue, Sep 15, 2020 12:08 AM
