caterpillar d7m oil cooler bipass?
Showing 1 to 10 of 10 results
jordan crunden
Send a private message to jordan crunden
has anyone ever bypassed the oil cooler on a caterpillar d7m? will this be ok to run and get hot?
Wed, Apr 15, 2015 2:03 PM
mrsmackpaul
I have a D7 3T that has the cooler disconnected it would appear that both the pipes have bean squashed and crimped over and soldered up I have asked is there something else that is done inside the filter housing
the reply was always NAH JUST BLANKEM OFF SHE'LL BE RIGHT AND IT WONT GET HOT
So I dont know if there is any big difference with the cooler or not I have being told that with todays oil the cooler is no longer required I really dont know though
I am currently fitting a nose cone ect off a 17A on mine and it has the oil cooler and I will connect it back up so time will tell for me
Paul
Wed, Apr 15, 2015 3:44 PM
jordan crunden
Reply to mrsmackpaul:
Paul
ok Paul thanks. my old man also says it will be fine to just get rid of the cooler so I think im going to fit a copper pipe from the supply and back round to the return and hopefully my oil pressure wont drop if she gets too hot. it just seems a disaster waiting to happen with these old original coolers that are wafer thin especially if your at a show with your cat and it dumps its oil without you really noticing.
Jordan
Wed, Apr 15, 2015 4:07 PM
Thank you received: 79
Reply to jordan crunden:
Jordan
Hi Jordan,
someone did this loop on a machine model that I cannot recall.
They made the bypass loop with copper plumbing fittings--looks like Yorkshire to me--with a show machine I do not think you will have any oil overheat problems in England.
Doing it this way you do not have to worry about any alterations to any of the bypass valves etc in the filter housing.
Thu, Apr 16, 2015 9:17 AM
Bruce P
Thank you received: 33
Reply to edb:
Hi Jordan,
Hello Jordan, when the radiator ( and oil cooler) was stollen out of my 7M, I just looped a piece of 3/4" oil hose over the fittings. The ends on the line act like hose barbs, didn't leak a drop. There was no effect on oil pressure. A couple hours in the field harrowing made little heat in the oil (it was a cool day). I have since found an oil cooler and installed it. With the grill installed you really couldn't see the hose loop.
Bruce P
Thu, Apr 16, 2015 10:36 AM
Inter674
Reply to Bruce P:
Bruce P
you could also look out for a filter base that does not have the bypass. I fitted later model D47U filter base to my D25U and it worked a treat.
Not sure if they are the same for a D7 tho - but again you could source a later model d7 base and do the same and it looks a lot neater.
Otherwise just short circuit the system.
Thu, Apr 16, 2015 10:55 AM
jordan crunden
Reply to Bruce P:
Bruce P
[QUOTE=Bruce P;142691]Hello Jordan, when the radiator ( and oil cooler) was stollen out of my 7M, I just looped a piece of 3/4" oil hose over the fittings. The ends on the line act like hose barbs, didn't leak a drop. There was no effect on oil pressure. A couple hours in the field harrowing made little heat in the oil (it was a cool day). I have since found an oil cooler and installed it. With the grill installed you really couldn't see the hose loop.
Bruce P[/Q
Ok thanks Bruce,
so its not really very high pressure if it didn't blow off? we are having some flexi hydraulic hose made up with male fittings on both ends but we are struggeling to identify the femal thread type on the flow and return pipes as we have measured it but it falls between an american style thread and britsh style? with 5/8 BSP 14 threads per inch being the closest? if this does not work we was just going to push rubber pipe over both pipes and put a decent hose clamp either side and pray for no leaks!
Jordan
Fri, Apr 17, 2015 12:25 AM
Thank you received: 60
Bruce P[/Q
Ok thanks Bruce,
Jordan
Easiest way is to get a couple of O-ring faces seal plugs.
They are 5/8" dash 10 1"-14 tpi straight thread.
Remove the face o-ring and stretch an o-ring over the threads along with thread sealant.
Remove the oil cooler bypass plunger and spring.
Fri, Apr 17, 2015 12:47 AM
ag-mike
[quote="Old Magnet"]Easiest way is to get a couple of O-ring faces seal plugs.
Remove the oil cooler bypass plunger and spring.[/quote]
this.:usa2:
+ if u want to keep ur original fancy polished copper tubing to ur leaking oil cooler remove oil cooler bypass plunger with spring and PLUG the copper lines.
Fri, Apr 17, 2015 2:35 AM
mrsmackpaul
Reply to ag-mike:
this.:usa2:
So if mine has been blocked off at each pipe would I expect to find the bypass plunger and spring removed ???????
Paul
Fri, Apr 17, 2015 6:20 AM
ag-mike
Paul
[quote="mrsmackpaul"]So if mine has been blocked off at each pipe would I expect to find the bypass plunger and spring removed ???????
Paul[/quote]
it would be best that it is. if it ain't, then its having to open and bypass, do its designed job as if the is line accidentally stopped up or kinked. so if u r going to stop flow through the line on purpose then go ahead and remove the bypass parts so it doesn't stop working for any unknown reason. good luck with ur projects.
Fri, Apr 17, 2015 6:54 AM
