Caterpillar d330 engine head help
Justinc
Send a private message to Justinc
Hi guys i recently purchased a second hand replacement head for my 955h the problem is the new head has a tube running through the intake manifold do any of you know what this may be my guess is an exhaust or somthing of that nature ?
Fri, Jul 1, 2016 9:32 AM
Pony motor exhaust heat exchanger....... helps to warm the air for starting the diesel in cold weather. Will not hurt to block it off in place or can be removed and the openings blocked.
Fri, Jul 1, 2016 9:38 AM
Justinc
Your the man thanks
Fri, Jul 1, 2016 10:09 AM
