Caterpillar D-4
Caterpillar D-4
Dozer69
Send a private message to Dozer69
I've Run Across a Pair of 'Mint' (90%)
D-4 Tracks. Grousers, Bushings, and
Pins.
Also, Top and Bottom Rollers.
Now, will Cat D-4 Tracks and Bottom
Rollers Fit a 1954 D-2?
Thanks,
Mike Painter
Mon, May 15, 2017 9:02 PM
STEPHEN
[quote="Dozer69"]I've Run Across a Pair of 'Mint' (90%)
Pins.
Thanks,
Mike Painter[/quote]
Mike that is a no go, but they will fit my D4! 😮hwell::whoo:
Thanks, Stephen
Mon, May 15, 2017 9:46 PM
Get the part number off the links or the model of the tractor they came off and you will know for sure what you are looking at, but as Stephen said, no D4 tracks ever fit a D2.
D2 tracks are supposedly available from aftermarket suppliers, but the pool of good-used tracks is pretty dry since there hasn't been a D2 or other model (933?)using the same track produced since 1959 or so. I believe the 933 track loader went to D4 size track components pretty soon after the last D2 came off the line.
Tue, May 16, 2017 9:48 AM
Dozer69
Reply to STEPHEN:
Pins.
Thanks,
Thanks, Stephen
[quote="STEPHEN"]Mike that is a no go, but they will fit my D4! 😮hwell::whoo:
Thanks, Stephen[/quote]
Hey,
'Thanks' for that All too Funny, truly (smile) ...
... Mike ...
Thu, May 25, 2017 11:13 AM
Dozer69
[quote="ccjersey"]Get the part number off the links or the model of the tractor they came off and you will know for sure what you are looking at, but as Stephen said, no D4 tracks ever fit a D2.
D2 tracks are supposedly available from aftermarket suppliers, but the pool of good-used tracks is pretty dry since there hasn't been a D2 or other model (933?)using the same track produced since 1959 or so. I believe the 933 track loader went to D4 size track components pretty soon after the last D2 came off the line.[/quote]
Hey,
'Thanks' for Your Your Insightful Information. Now that
I've Read it. I 'Think' Your Right about the 933 Cat Loader.
'Thanks Again',
... Mike ...
Thu, May 25, 2017 11:17 AM
| Kingaroy, Queensland
