caterpillar 518 skidder
d47u
Send a private message to d47u
I've got a problem with my skidder. I got some bad fuel and got water. I drained the water new fuel filter got it bled out and running. Now the problem. It runs like crap. It has a fuel knock and pours out black smoke when idling. Is it possible the water messed up the injector nozzles? It was running fine until it quit from the water. Thanks
Tue, Feb 23, 2010 11:06 PM
Sounds likely to me! I know it doesn't happen every time, but it sure fits in this case.
Have you loosened each injector line in turn to see if you can eliminate the knock and smoke by cutting out one cylinder/injector? Maybe the knock and smoke are from different ones😮
At the very least you will have it bled out good.
Tue, Feb 23, 2010 11:19 PM
d47u
Thanks for the reply. The day after I posted this we got about three feet of snow. Had a few warm days this week that took the snow down some so I messed with the skidder today. When you crack the second injector back from the front of the engine the smoke and knock goes away. So I guess I found my problem. Now for the next question. Do you need any special tools to get the injectors out? Also do I have to replace the whole injector or is just the tip replaceable? The engine is a 3304. Thanks
Sun, Mar 7, 2010 5:23 AM
bob
Send a private message to bob
Reply to d47u:
Get an EXCH injector. But you should try to swap a couple first and see that the problem moves with the current bad one.
Later Bob
Sun, Mar 7, 2010 10:54 AM
| Kingaroy, Queensland
