Caterpillar 20 wheel tractor.
josh
Thank you received: 13
Pictures of a Twenty on wheels, built by Cat for test purposes?
Tue, Feb 20, 2007 9:14 AM
biggastractor
Wow, Neat picture. could someoe comment on the steering of that prototype? Do I see steering rods going to the front axle? Or was it just clutches and brakes like normal?
Thanks for posting
Biggastractor
Tue, Feb 20, 2007 10:11 AM
2HIGHTEN
Send a private message to 2HIGHTEN
Reply to biggastractor:
Thanks for posting
Biggastractor
I have a ten that was converted at old cat dealership , to rubber tires.
It has 24 inch tires on the rear and i6 inch on the front, used a steering sector and linkage to steer, the brakes were reconstructed to cable control and release steer clutch and then if apllied further apply the brake to each side seperately, I brought this tractor from the man that used it for many years and helped to reconstruct it, He said it worked really well and would pull two 14 inch plows easily. It is complete and would be easy to restore
questions or comments call Ron Meeder 716-761-6447.
Tue, Feb 20, 2007 10:25 AM
R4catkid
Send a private message to R4catkid
Reply to 2HIGHTEN:
any pics of your wheeled ten???
Thanks, -R4catkid
Thu, Feb 22, 2007 8:40 AM
2HIGHTEN
Reply to R4catkid:
Thanks, -R4catkid
I will locate some from when we purchased this tractor, It has been a while ,so give me a day or so. The man said they built it at the dealership during the war because of shortages or steel and they wanted a faster way to get things done He also said it worked well I may restore it on wheels someday.
Thu, Feb 22, 2007 9:18 AM
KJM
Send a private message to KJM
Reply to 2HIGHTEN:
Ron what would you like to get out of the wheeler ten? what part of new york is ripley in? thanks kyle 914.474.7621
Sat, Feb 24, 2007 10:16 PM
