Caterpillar 140 Blade Lift Issues
Showing 1 to 9 of 9 results
farmallzach
Send a private message to farmallzach
I have a 1971 Cat 140 Grader, 11R679, I have been using it heavily the last 2 weeks, I have spead over 200 loads of gravel with it in the last 3 days, any way, when I go to let the left side of the blade down it it some times just falls down, it always does it when you are letting the blade down, once it stops it stays put, but it don't always do it, it usually does it later in the day when things get warmed up. It got worse today and made doing finish work a real pain in the butt. I tightend the brake up but that didn't help. Any advice would be appreciated, I got another 200 loads of gravel to lay out with the Ol' girl. Thanks, Zach :frusty:
Sat, Jul 30, 2011 10:16 AM
Had to get the books out......
The blade lift and lower clutches are different than for the other controls. It depends on an internal spring loaded clutch to act as a brake to control drift. I suspect your clutch and spring assembly is worn out and there does not appear to be any adjustment.
Sat, Jul 30, 2011 10:35 PM
Thank you received: 140
Hi, Farmallzach.
It is not uncommon for this to happen when the pinion adjustment under the hi-lift gear needs taking up. That is not to say that the brake mechanisms in the control box that Old Magnet mentioned are not worn but loose pinon bearings can also contribute.
Do not over-tighten the pinions or it will tell you all about at the end of the control levers. With no weight either up or down on the blade lift arms, loosen the lock nut and screw the pinion adjustment in until it is just barely firm and hold it securely while you tighten the lock nut.
Hope this helps.
Sun, Jul 31, 2011 1:27 AM
farmallzach
Hi, Farmallzach.
Hope this helps.
Thanks! I will give that a whirl.
Sun, Jul 31, 2011 1:57 AM
Reply to farmallzach:
I would expect worm gear backlash would contribute some but not be sensitive to temperature change as described. This seems more indicative of a marginal clutch....slipping during engagement/disengagement but holding once the clutch dogs are engaged. Would be very annoying trying to hold a grade.
Sun, Jul 31, 2011 4:28 AM
farmallzach
Its very anoying, it ALMOST makes me wish I had a Hydraulic grader.
Sun, Jul 31, 2011 6:09 AM
My manual doesn't say much about the brake....just adjust as required so that the brake band contacts the shaft. I am thinking this is supposed to work in conjunction with the control clutch to minimize drift.
Are the brakes in good order and operating?
Sun, Jul 31, 2011 10:41 AM
farmallzach
Yes They are, That was the first thing I checked.
Mon, Aug 1, 2011 5:40 AM
farmallzach
Hi, Farmallzach.
Hope this helps.
[quote="Deas Plant."]Hi, Farmallzach
Hope this helps.[/quote]
Thanks for the advice, that was the ticket, she worked almost as good as a new grader the last 2 days, now if I could only find where the air conditioner belt goes I would have it made! 😆
Wed, Aug 3, 2011 7:31 AM
Glad to hear you'r all tuned up.....nice to snag an easy fix every now and then.
Wed, Aug 3, 2011 8:20 AM
