catd6c /10k
catd6c /10k
keith-52
Send a private message to keith-52
I have been rebuilding pond dam and have noticed pushing up hill a scraping type noise. after inspecting have found left side inner sprocket teeth rubbing on inside of track chain. complete track roller frame needs to be moved over to right 1/2 inch or so.N sure how to go about shifting over complete frame assembly to the right side to get off the left side sprocket. thanks keith both rear sprockets tight , not bent and no movement with pry bar
Wed, Sep 21, 2016 1:29 AM
Thank you received: 52
Check the track frame alignment. Also the position of the inner swing frame bearings. If they are jammed up against the case your not going to be shifting the track frames.
Wed, Sep 21, 2016 3:29 AM
keith-52
inner track frame bushing take grease, and have travel room to the left or right. Track frame needs to move over to right side . Could Iget some guidance on steps to move frame over to the l right 3/4 to 1 inch. I have purchased shims and cap gaskets, I hope track frame does not have to be droped down, thanks keith
Fri, Sep 23, 2016 10:07 PM
