CAT22 Rebuild Progress
Showing 1 to 10 of 12 results
Although progress is very slow, things are starting to come together. Recently I married the engine and Transmission. See photo. The following things have been done to the engine and transmission: Engine-
• Rebuilt head (valves, seats, springs)
• Block boiled
• Cylinders bored and sleeved
• Piston rings replaced
• Crank ground and polished
• Main and rod bearings re-babbitted
• Seal and gasket set.
• Radiator boiled & pressure tested
• Flywheel ring gear removed, flipped and turned 90 degrees, chamfers cut on teeth
• Clutch disk refaced
• Clutch throwout bearing replaced
• Generator re-wired for 12 volts, replaced generator drive gear
• Carb rebuilt
Transmission-
• New clutch/brake pedal shaft
• Clutch and brake pedals bored and bushed
• Clutch pedal shaft bearings in bell housing bored and bushed
• Transmission input shaft bearing and seal replaced
• Engine clutch brake re-lined
• PTO bearings replaced
• Steering clutch operating handle guide replaced
See attached photos.
I hope everyone has a wonderful Christmas and an even better 2014. Ray[attachment=20980]DSC_0024.jpg[/attachment][attachment=20979]DSC_0023.jpg[/attachment]
Wed, Dec 25, 2013 11:19 PM
Steve A
Nice progress and quality work--Very Nice
Thu, Dec 26, 2013 12:59 AM
Norm R2,22
Send a private message to Norm R2,22
Reply to Steve A:
Did you re-Babbitt your own bearings or did you have it done?
Thu, Dec 26, 2013 1:04 AM
Reply to Norm R2,22:
Norm, I do not have the equipment needed to do the re-babbitting so I took it to an old guy who does nothing but babbitting. He must be about 200 years old, and came highly recommended by NAPA as well as some ACMOC members. I am very pleased with his work. Ray
Thu, Dec 26, 2013 2:21 AM
Norm R2,22
I would assume that the "Old" guy is in the Albany area?
Fri, Dec 27, 2013 5:52 AM
Yup, he is less than an hour North of here in Ft Edward, NY. He has a one man shop called, strangely enough, The Babbitt Pot. (51😎 747-4277
1693 State Route 4, Fort Edward, NY
Fri, Dec 27, 2013 7:33 PM
64farmboy
Reply to Steve A:
Ray, I agree nice job!!!
Regards Dennie
Fri, Dec 27, 2013 8:53 PM
pbamburak
Send a private message to pbamburak
Reply to 64farmboy:
Regards Dennie
Ray,
Which paint code and manufacturer did you use? I am using a Dupont 421a (found the number in the archives) but it looks too light to me.
Paul Bamburak
Trenton, NJ
Fri, Jan 10, 2014 7:03 AM
Dan Pratt
Reply to pbamburak:
Ray,
Paul Bamburak
Trenton, NJ
Where did you find a replacement generator drive gear? Did you make it?👋
Fri, Jan 10, 2014 7:43 AM
Reply to pbamburak:
Ray,
Paul Bamburak
Trenton, NJ
[quote="pbamburak"]Ray,
Paul Bamburak
Trenton, NJ[/quote]
Paul,
I use Rustoleum Old Cat Yellow Acrylic Enamel on top of cold galvanizing compound. I get my paint from Zoro Tools. I have been very satisfied with the color match based on what I find in non-exposed areas on the tractor. I am not building a show Cat, but a gentleman farmer's Cat. I'll push some dirt around with it, and pull some stumps. It has an Issacson blade and hydraulics on it.
Ray
Sat, Jan 11, 2014 8:41 AM
Reply to Dan Pratt:
Dan, I found a replacement generator drive gear from Wally Adams on this site. When I get some time I may try to repair the gear I have, but it was chewed up pretty bad.
Ray
Sat, Jan 11, 2014 8:43 AM
