CAT values
CAT values
Showing 1 to 9 of 9 results
ETD66SS
Send a private message to ETD66SS
Considering selling off some or all of my equipment, wondering the current value of my CAT equipment.
D6C 10K- has ~6500 hours (would need to remove sight glass to get accurate hour reading), runs great, needs complete UC except pads and maybe idlers. Track adjusters work, but they don't hold, I assume new seals are needed. Not sure how to tell how worn the brakes & clutches are, but still turns fine. I was considering putting on a Korean import UC, but I'm not sure what the point is as I have only started the tractor ~three times in the last 5 years to move it out of my way... Also has a leaking exhaust manifold, bought all new studs and gaskets but have been leery to dive into that project because it is almost guaranteed I'd be taking off the head at some point due to broken studs. I'm not a diesel mechanic, not sure I want to mess with the injectors, injector pump etc just to change exhaust manifold gaskets...
225LC 51U - Has around 6500 hours (from memory, would need to go look at the hour meter), however the hour meter is a Hobbes not a CAT, so not sure what the real hour count is. Finally figured out the overheating issue on this one, it wound up just being the previous owner was too cheap to re-core a radiator that was very clogged. Radiator has been re-cored, I added a 6 blade fan, and rebuilt all the baffles. I also rebuilt the oil filter heat exchanger (not exactly sure if that's what it's called, don't have my parts book on me atm) as it was leaking engine oil. The 225 still needs 7 pins to be unstuck on the chains that are only 20% worn, 5 on one track, 2 on the other. Still needs the track brakes re-sealed as they are dumping HYD fluid into the final drives, they were doing this the whole time I have owned the machine. One of the track springs is broken. Even though the chains are only 20% worn, the UC needs new top rollers and idlers, the pads are all bent up too, rest of the UC was replaced not long before I bought the machine. They tried to weld up the existing idlers but did a crap job, they should just be replaced. As far as leaks, only leak left is one of the tank return lines from the rear main pump, not a high pressure line but has been weeping HYD oil since I bought the machine, all 3 tank return lines should be replaced. Both boom cylinders need to be re-packed, and the bucket curl hoses are about ready to pop, those should be replaced before the next job. One nagging issue on this machine has always been the slow boom lift when oil gets hot. Bob Ont was trying to help me along with that before he passed, it sounded to him like I needed valve shimming, but I never delved into that as it sounded like a bit of a since project to get right.
Both machines have their issues, the D6C needing more $$ put into it, but they both run and operate well. I did a lot of work with them over the last ~13 years or so. I likely overpaid for both machines when I bought them, $21k for the D6C and $23k for the 225LC. I probably have $50k total into both machines including maint./repair I know that if I sell them there will be future jobs that I wished I still had the machines, but for now they have just been sitting. They don't make money for me, they are just for personal use on the same piece of land. If I can't get $35k back out of them, I think I'll just keep them.
[img]https://i.imgur.com/xmLkO66.jpg[/img]
Thu, Oct 12, 2017 7:53 PM
jstandle
Send a private message to jstandle
Not sure in your neck of the woods but a D6C 10K starts around $15k here with lower % u/c in running/operating condition on up to $30-35k and depending how they are spec'd (canopy, winch, tilt, angle, brush, ripper, etc). Average lately seems to be $20-25k for one in decent condition. But again, that is Oregon not NY.
I'm not sure on your 225, I've never paid attention to excavator prices.
https://spokane.craigslist.org/for/d/caterpillar-d6-dozer/6329133365.html (not sure if that is a 10K)
https://eastidaho.craigslist.org/hvo/d/d6c-cat-dozer/6314395771.html
https://portland.craigslist.org/clc/hvo/d/d6c-dozer/6342198758.html
https://eastoregon.craigslist.org/hvo/d/d6c-cat/6303352551.html
Fri, Oct 13, 2017 5:30 AM
JoeG
Send a private message to JoeG
Reply to jstandle:
Not to hijack your thread but have you finished your pond project? Would love to see some photos of it if you have.
Fri, Oct 13, 2017 5:51 PM
ETD66SS
Reply to JoeG:
Oh yes, the ponds have been done for years now. I have one spoils pile left to deal with, and then I pretty much don't really need the CAT machines anymore. Trying to figure out if I need to justify keeping them, or selling them for a some extra cash to help build my house.
I guess the best picture to show the pond project progression is this one:
[img]https://i.imgur.com/iXMdzJz.jpg[/img]
We had a drought in 2016, the Google Earth pic here shows how low the water level was:
[img]https://i.imgur.com/ZQqSK0J.png[/img]
2017 was very wet, ponds looked much better and were not choked with weeds, I don't have any pictures handy though.
I know that someday I'll be kicking myself for selling the D6C and 225, but the last 3 years they probably have 4-5 hours combined on them... It seems like I will lose quite a bit of money selling them, so I guess that's the decision.
Fri, Oct 13, 2017 6:51 PM
JoeG
Reply to ETD66SS:
Nice pictorial of things there, very nice.
Sat, Oct 14, 2017 1:37 AM
ironman3406
Chapter Twenty Seven
Send a private message to ironman3406
Reply to JoeG:
You might try going onto the Ritchie Brothers Auction site and looking at past Auction results. That will give you the best indication of what the market is paying for particular models. I use it all the time for calculating fair market values at work.
Good luck looks like they worked well for your projects.
Cheers
Nathan
Sat, Oct 14, 2017 2:01 AM
ETD66SS
Reply to ironman3406:
Cheers
Nathan
[quote="ironman3406"]You might try going onto the Ritchie Brothers Auction site and looking at past Auction results. That will give you the best indication of what the market is paying for particular models. I use it all the time for calculating fair market values at work.
Cheers
Nathan[/quote]
Ok, so I tried that, and unbelievably, there are no results for D6C's from rb over the last 2 years, that seems rather incredible.
But this sold for $5k? https://www.rbauction.com/1967-CATERPILLAR--CRAWLER-TRACTORCTR?invId=10109408&id=ar&auction=ALBUQUERQUE-NM-2017201
WOW!
Sun, Oct 15, 2017 2:23 AM
ETD66SS
Reply to ETD66SS:
Cheers
Nathan[/quote]
WOW!
This is a near twin to my D6C https://www.rbauction.com/1970-CATERPILLAR--CRAWLER-TRACTORCTR?invId=10075738&id=ar&auction=KANSASCITY-MO-2017198
Mine is a 10K401, which iirc makes it a 1968. Not sure when turbo's were re-introduced to the D6C.
These past auction results don't help much because I can find D6C's that sold for $30,000 and some that sold for $5000, but I have no idea on condition of the machine, or the UC wear etc.
Sun, Oct 15, 2017 2:49 AM
8C 361
Reply to ETD66SS:
How can you think of selling those fine machines? Don't you have yellow fever?
Sun, Oct 15, 2017 5:55 AM
JDcat
Send a private message to JDcat
Reply to 8C 361:
Try MachineryTrader.com Caterpillar D6C Auction Results.
Hope this helps.
John
Sun, Oct 15, 2017 8:51 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
