Cat Twenty Parts Needed
d2steph
Send a private message to d2steph
Hello everyone, I picked up a Twenty yesterday at Ken Avery's. I need to find some parts, crank handle. side curtains, hood latches, top rollers and most important if there is no tag is there any other way to ID the tractor. By any chance do the top rollers match any others.
Sun, Oct 20, 2013 7:44 PM
Steve A
I should have the top rollers, the serial number is stamped on the top of the transmittion case just ahead of the seat next to the trans cover, did you need a air cleaner also ?
Sun, Oct 20, 2013 9:29 PM
d2steph
Reply to Steve A:
Thanks for the info, both top rollers have internal issues. Yes I also need air cleaner parts. Would the ID be near the shift pattern tag.
Sun, Oct 20, 2013 10:29 PM
Steve A
Reply to d2steph:
The serial on mine is stamped in the top of the trans housing between the 2 oilers just behing the trans shifter cover plate, the first digit is 3 inches to the left of the right oiler if your siting in the seat, at the edge of the trans cover.
Mon, Oct 21, 2013 1:27 AM
