Cat Twenty hand crank handle
Showing 1 to 10 of 10 results
ErnieinTucson
Send a private message to ErnieinTucson
Hi all Ernieintucson
Need a crank handle for a Twenty. Also is a crank for a Ten the same as a twenty?
Thanks Ernie
Wed, Jan 28, 2009 11:17 PM
d4e
Send a private message to d4e
Ernie,Here is John Mattas number he may be able to help you.951-689-6475. He is located in Riverside Cal.
Wed, Jan 28, 2009 11:40 PM
WyoCat
Reply to d4e:
I believe it would depend if you have the big 20 or the small 20. Jim Zimmerman also has these hand cranks reproduced in cast iron instead of cast brass.
Chad Enyeart
Thu, Jan 29, 2009 12:05 AM
truckun95
Send a private message to truckun95
Reply to WyoCat:
I am looking for a hand crank for a big TWENTY part of the #L-1185 crank assembly.
Sun, Nov 23, 2014 7:48 AM
tomseabee
Send a private message to tomseabee
Reply to d4e:
I think John is no longer in the Cat business. I understand he sold out recently. It wouldn't hurt to call him and see if in fact he did sell. He also might have a few items stuck away in the corner.
I bought one of John's cranks for my Twenty several years ago. It's a quality item like all his stuff.
You might also check with Chad Enyeart. I know he has a lot of big Twenty stuff and is a great guy to work with. I think Chad bought Jim Zimmerman's Cat stuff.
Good luck,
tom
Sun, Nov 23, 2014 8:05 AM
truckun95
Reply to tomseabee:
Good luck,
tom
Thanks Tom,
I did happen to check with John a few months ago and followed a lead he gave me but ended up with no luck. Also I have checked with Chad on the handle recently and at this time he did not have one. So hoping to see if someone out there may have an extra one sitting around they would be welcome to part with.
Sun, Nov 23, 2014 8:11 AM
Mike Meyer
Reply to truckun95:
Thanks Tom,
I bought all of John Matta's crank handles and other assorted parts about 2 months ago, they are sitting up in Oregon at Scott Hayes place right now and to be honest I'm not sure if there were any 20 cranks amongst them all, I know there were cranks for 15's and 22's, and 30's, I'll contact Scott and ask for you.
Regards
Mike
Sun, Nov 23, 2014 9:25 AM
blakeystew
Send a private message to blakeystew
Reply to Mike Meyer:
Regards
Mike
Hi, try lance jones I got mine off him,he is a real good guy and good to deal with.
He might be able to help you.
Thanks stew
Sun, Nov 23, 2014 4:26 PM
truckun95
Reply to blakeystew:
Thanks stew
Refreshing posting
Sun, Nov 30, 2014 11:50 PM
Texasbest
Send a private message to Texasbest
Reply to truckun95:
Refreshing posting
I can use one also if someone has them.
The 2 I've got have both been welded.
Roby Whitehead
Mon, Dec 1, 2014 2:50 AM
truckun95
Reply to Texasbest:
Roby Whitehead
Refreshing, after further investigation I believe the handcrank casting part number would be L-233.
Wed, Dec 24, 2014 10:08 AM
