cat twenty clutch questions
d2steph
Send a private message to d2steph
Hello everyone, my cat 20 has a problem, when the master clutch is released or dis-engaged, the linkages on the throwout bearing are going over center and jams the bearing from pivoting foward to re-engage against the pressure plate. Any info would help, thanks.
Fri, Feb 19, 2016 11:00 PM
Thank you received: 36
Hi d2steph,
welcome to the BB.
Alas, to help you further we need a Serial Number as there are two models of Twenty Tractor.
The Small Twenty has a side valve engine and the Large Twenty has an overhead valve engine.
They can also be known as the Big Twenty starting at S/no's L1-up or PL1-up or the Small Twenty S/no's 8C1-up.
Main problem could be that there is too much clearance to where the clutch brake becomes effective--this would allow over travel of the release mechanism before the clutch brake engages, this action stops over travelling such as you describe.
Hope this helps.
Sat, Feb 20, 2016 6:48 AM
d2steph
Reply to edb:
Hi d2steph,
welcome to the BB.
Hope this helps.
Your are on point with the problem, it is a big twenty, #PL639 i can see that there to much travel. the clutch brake is still good but i think the main clutch is worn . it is about 1/8 inch thick
Mon, Feb 22, 2016 9:22 PM
