Cat Thirty valves and related ideas
Showing 1 to 10 of 14 results
STEPHEN
I have been working on the head for the Thirty. After taking a hard look at the overall wear, I decided to change the valve guides and valves. I will turn guides from cast iron bar stock and will modify some diesel valves by adjusting the head diameter, length, and lock grooves.[attachment=54034]20190523_221547.jpg[/attachment]
One thing I thought was interesting was the name "Thompson" on many of the old valve heads. A quick trip to the internet found some history of the company that became the T in TRW. Seems the company was founded on the idea of making valves by electrically welding the heads to the stem.[attachment=54033]20190523_221243.jpg[/attachment]
The diesel valves are available after market for around $20.00, if it works out I would be open to modifying valves for fellow members.
Fri, May 24, 2019 10:13 AM
Walt D7-3T
Send a private message to Walt D7-3T
STEVEN,
Just and FYI. your other post, a duplicate, has been removed for you.
Fri, May 24, 2019 11:20 AM
STEPHEN
Reply to Walt D7-3T:
STEVEN,
I made these two guides from 36" of cast iron bar stock, the rest I junked because I was working late at night & didn't have my head screwed on right. Anyway they went in well. I did make a few alterations, tapering the end for flow and turning a lead to get them started straight. [attachment=54073]20190525_151426.jpg[/attachment] One old guide showed .019" movement with a new valve so these will do nicely.
Sun, May 26, 2019 8:35 AM
Bruce P
Thank you received: 9
Reply to STEPHEN:
Those look really nice Stephen!! Good work.
BP.
Sun, May 26, 2019 9:38 AM
STEPHEN
Reply to Bruce P:
BP.
[quote="Bruce P"]Those look really nice Stephen!! Good work.
BP.[/quote]
Thanks, I hope to get the rest made & the new valves addressed next week. This engine has been apart too long.
Sun, May 26, 2019 10:42 AM
STEPHEN
Reply to STEPHEN:
BP.[/quote]
Ok, had a little excitement here today, got a new to me J&S wheel dresser in the mail for working the valve lock grooves. Got everything setup on the surface grinder and put in two lock grooves, so far so good but think I need a spinner handle on the rotating fixture. I also want to put in the narrow groove for the circlip in case a valve spring lets go one day.
Wed, May 29, 2019 3:40 AM
STEPHEN
Reply to STEPHEN:
I was going through the rocker shafts, not because I suspected anything bad, but just to spruce them up before getting new oil into the engine. Anyway, after disassembly I ran some solvent into the oil port and noticed that some of the rocker oil holes seemed restricted. The ends of the shaft were stopped up with core plugs, and after removing them, " holy Toledo " as grandpa used to say. The muck & sludge inside was incredible. Luckily I keep a good selection of tube brushes around and after some brush turning with the drill, all came up clean.
The core plugs were the odd size of 25/32 , the next size readily available was 20mm. I made a quick fixture in the lathe and turned a little off the OD. I really didn't check around much for the proper size because I needed some progress today. Anyway, everything worked out fine and I should be able to set the lash in the morning.
Wed, Jun 19, 2019 12:48 PM
Thank you received: 32
Reply to STEPHEN:
Hi Stephen, your handiness with a lathe goes to show how useful it is when dealing with old junk where parts aren't readily available. Maybe when I retire I can start acquiring some of those skills : )
Wed, Jun 19, 2019 5:44 PM
STEPHEN
Neil, I have a few machine tools with your name on them!
Wed, Jun 19, 2019 6:09 PM
mog5858
Reply to STEPHEN:
nice work I thought all spin fixtures had a speed knob on them. can you PM a price on a new set of valves as I got a thirty motor apart right now too and I see you'll all tooled up and set up. Don't Neil it's a trap machines are the easy part then you need time and well they take up space that could hold future projects. but the best part is you'll be the most popular neighbor around once word get's out you got a lathe. just a rule of thumb you will spend the same amount on tooling to make the lathe useful as you did buying the lathe. that's being said I am too far gone I got to mean future projects and a shop full of lathe and mills and a few stashed at a friends house too. did I mention there an auction sale this weekend?
Fri, Jun 21, 2019 7:49 AM
Reply to mog5858:
Heh, well I'll willingly go there : )
Fri, Jun 21, 2019 10:29 AM
