Cat Thirty Oil Pressure
Showing 1 to 10 of 12 results
TomP-TX
Online
Send a private message to TomP-TX
Here is my latest project. After spotting this tractor a couple of years ago I was finally able to purchase it this summer. I don't think it has been started in at lease five years but after making a few repairs and rebuilding the carb. I was able to get it started. The oil pressure needle was very low but I removed the valve cover and everything looked like it was getting oil. After looking in my manual it says that the oil pressure should be 10 psi when warm. I also found this post: http://www.acmocbb.org/ACMOC_BB/showthread.php?t=4396&highlight=oil+pressure+gauge talking about the old gas Cats having 4 to 10 psi. I think the 7F9084 has been replaced again. My question is there a gauge available that has a low scale so the needle will register high when running or will I have to find a old original style gauge?
Tom
Thu, Nov 5, 2009 9:03 AM
SJ
Send a private message to SJ
At the dealer for dyno testing I always used the calibrated gauges so I knowed where things were and I can,t remember if Cat sold that type but it seems our local truck and auto. parts store sold them here that we dealt with.Yes there is different types of them, some with low pressure maybe up to 30 PSI for fuel pressure etc. and some higher ones for engine oil pressure.I also had one of the lower pressure ones for turbo boost. Boost by lbs. is half what inches of mercury (HG) is that Cat uses for the specs. of turbo boost.
Thu, Nov 5, 2009 11:54 PM
Mike Meyer
Reply to SJ:
On my 2 Ton I used a Stewart Warner gauge, it's an older style face and reads 0-50 pounds which is perfect because my tractor runs at around 30-32 pounds.
It is Stewart Warner P/N 82207 and cost about $US50 here in Oz. I'll try and post a picture for you, my first time trying that here on ACMOC.
Mike
Fri, Nov 6, 2009 6:05 AM
OzDozer
Reply to Mike Meyer:
Mike
Tom - For a test gauge, look on eBay and you will find hundreds of new surplus, or NOS gauges for sale at any one time, for reasonable $$'s.
A good quality gauge will have oil damping, and a large dial, with the needle doing at least a 270ยฐ arc of the face, and fine graduation marks.
If you search for an oil-filled gauge, with a fine-graduation-marked face, that reads 0-30psi maximum, you will have a satisfactory gauge for testing.
You will then just need to organise a suitable length of hose and fittings that allows you to tap into an oil gallery, and lets you read the dial satisfactorily.
Cat introduced re-calibrated gauges in 1951, to more accurately show low pressures, because many operators and owners were concerned about low oil pressures.
The previous gauge was 8B2355, the new replacement was 7F9084. The 7F9084 reads from 4-11 psi in the marked "operating" zone .. whereas the 8B2355 read from 10-40 psi in the "operating" zone.
Cat consistently repeated the information, that the old Cats (both gas and diesel) do NOT rely on high pressure oil for lubrication .. but on VOLUME of oil provided to the working parts.
Thus, you can have idling pressure of 4-5 psi, even on the diesels, and Cat still regarded that, as highly satisfactory oil pressure, on these old engines.
Once the newer range of redesigned, high speed diesel engines, were introduced from around 1959-1960 .. these engines were designed with, and require, higher operating oil pressures, and 4-5 psi is most definitely inadequate oil pressure for them.
The newer, high speed engines (1800-2000 RPM) run at approximately double the oil pressure of the old diesel engines.
Yes, you will have to find the 7F9084 gauge, to be able to have the low pressure showing accurately. Besides, a Cat gauge always looks better, and more original .. although it appears that the 7F9084 wouldn't be correct original, it would more likely have had the Sylphon gauge?
Here's a scan of the relevant 1951 Service Magazine article, when the re-calibrated gauges were introduced.
http://i38.tinypic.com/2qna0pw.jpg
Fri, Nov 6, 2009 6:57 AM
jmvmopar
Reply to OzDozer:
Here is that gauge 7b9084
http://www.machinerytrader.com/list/partsSearch.aspx?PCID=&dlr=&GUID=a149b2b091054d8e89b5db6fe70148bc&Manu=&Mantxt=&Mdltxt=&mdlx=Contains&PartNum=7F9084&btnPartSearch=Search&fullsearch=
Fri, Nov 6, 2009 12:53 PM
Curtis J
Send a private message to Curtis J
I have an old original 7F9084 oil pressure gauge in good condition, if someone needs it contact me.
Thu, Feb 4, 2010 2:22 AM
chriscokid
Reply to Curtis J:
Tom,
do you know were the street pads can from?
Oz,
your wealth of knowledge about cats is very impressive, If you put all of you data in cd form i am sure you would have lots of buyers.
I am not sure what the BB users would do without your input.
I feel the same way about OM and SJ as well.
I guess all great mechanics have two letters in their BB name.
Thu, Feb 4, 2010 4:45 AM
JasonPayneCrawlers
Reply to chriscokid:
Tom,
Oz,
Erik
Try this place http://www.superiortire.com/products/track_pads/index.php
looks like they have lots to offer๐Ÿ˜Š
Thu, Feb 4, 2010 8:26 AM
3J1Bill
Reply to JasonPayneCrawlers:
Erik
It looks like someone found new old stock WW2 Cletrac MG1 pads, for that CAT 30. They look good on the 30.
Thu, Feb 4, 2010 11:40 AM
Pat in WI
Reply to 3J1Bill:
Tom,
Oil gauge aside...that is wonderful looking tractor! The THIRTY has always been my favorite gas Caterpillar. It grows on me more and more. I think I would have one today but I don't have a trailer heavy enough to carry one.
I have two other restorations I must finish first though...but by then I may not want to tackle bigger projects anymore.
I sure like looking though...you have a beautiful tractor!
Maybe Erik will let me operate his this year! (hint hint) ๐Ÿ˜‰
Pat
Pat in WI
Thu, Feb 4, 2010 5:30 PM
TomP-TX
Online
Reply to Pat in WI:
Tom,
Pat
Thanks Pat, The thirty is also my favorite it seems to have a square look and everything proportionaly sized right.
I ended up buying the gauge off of machinery trader. I had to cut off the mounting plate that was spot welded to the gauge and then modified a washer with screws so I can mount the gauge to the bracket. The origninal mounting plate was just too big.
I'm not sure where the previous owner got the track pads. The have bf goodrich stamped on the side. Each pad has two steel plates under them. Here are some pictures.
Tom
Fri, Feb 5, 2010 9:59 AM
