Cat Thirty Hydraulic Pump
Showing 1 to 6 of 6 results
ED PONTE
Send a private message to ED PONTE
Did Cat Ever Make A Rear PTO Hydraulic Pump For Thirty's .
Wed, Jan 16, 2013 2:29 PM
chriscokid
Yes,
Mine is a BeeGee Pump and was mounted on a thirty
Wed, Jan 16, 2013 6:24 PM
Reply to chriscokid:
Yes,
I believe it was LaPlant Choate that provided the early pumps, don't think Cat had one at the time but I have no proof.
Wed, Jan 16, 2013 10:37 PM
willwingo
Thank you received: 8
LaPlant Choate provided most of the pumps and jacks (their term for what we call cylinders) for use with the bulldozers they manufactured.
There is a Caterpillar "Hoist Pump Group" with part # W-290-A, which included a bracket and gear pump (rear mounted) for use with the Sixty. There is also a "Hoist Pump Oil Tank and piping group, part # W-852-A, also for the Sixty. Several parts do interchange between the 30 and 60.
I have one of the Caterpillar pumps and it is not marked anywhere.
Here are a couple of scans from the Sixty Attachment Parts Catalog, Form 3098
Thu, Jan 17, 2013 8:14 AM
ED PONTE
Reply to willwingo:
Hey PhilDirt That Picture Look's A Lot Like Mine . Except Write Above Pump Body It Has A Round Cast Single
Valve Control Body .
Thu, Jan 17, 2013 12:24 PM
dick
Send a private message to dick
Reply to ED PONTE:
The 30 Be-Ge adapter for S and PS tractors is #2240A for the 1000 and 1400 series pumps. This may be difficult to find. The adapter for a 3 Lunger is Be-Ge #3328A, this adapter will fit the 30 main case but is probably to short for pump and tank clearance. A spacer would have to be made or possibly a Be-Ge clutch would add enough length. In the S and PS parts book it shows the front housing for the belt pulley attachment as the part number 1A2235 and the same number for the 3 Lungers. In the west there were lots of Be-Ge's on 3 Lungers for farm work. You would have to make up the shaft to fit. I still have a few Be-Ge parts available and Associated Tractor in CA has parts. 800-735-1301
Thu, Jan 17, 2013 10:07 PM
7upuller
Reply to dick:
Hey Ed,
I still have the two valve Bee Gee unit that came off the diesel 35, if that helps. In the shop is also the two valve unit that came off the 6-9u.-glen
Thu, Jan 17, 2013 11:57 PM
