Cat Thirty fan assembly help
Showing 1 to 6 of 6 results
Jed
Send a private message to Jed
[attachment=5741]jed 125.jpg[/attachment] [attachment=5740]jed 126.jpg[/attachment] See attached pictures of the fan assembly on my Cat Thirty. While running, it sounded like a bad bearing on the fan shaft but after removal, bearings seem fine. I think it's this spring and washer making all the noise. I know this spring is what keeps tension on the fan blades, but it doesn't seem right just grinding around as the fan spins. Does it get lubricated by the oil or maybe apply some grease? Thanks.
Jed
Sat, May 1, 2010 3:59 AM
Jon
Send a private message to Jon
is there any of the clutch material remaining, or is it metal to metal? was the rear key in place when you took it apart?
Sat, May 1, 2010 7:48 AM
Jed
Reply to Jon:
Yes there is material on both sides of the fan and the rear key was in place. The spring was under compression too. I looked in the parts book and I think I have all the right parts but it really has me baffled as to why there is metal to spinning metal contact in there.
Sat, May 1, 2010 9:32 AM
Caterpillarman
Send a private message to Caterpillarman
Reply to Jed:
The noise you are hearing is from the gears that drive the fan. I have never heard a thirty yet with a quiet fan. The spring puts pressure on the sliding collar in your picture to keep the fan clutch tight. The spring rotates with the fan shaft, there is no metal to metal spinning of the spring, it sits stationary on the fan shaft. I hope I explained this so its understandable. Study the assembly a little and you'll see what I am talking about. As for the noise, its just a quirk of the cat thirty, mine does it pretty loud. Caterpillarman
Sat, May 1, 2010 1:43 PM
Jed
Reply to Caterpillarman:
Thank you. I see now that the large washer inside the housing is sitting against a shoulder on the shaft. That is what the spring is putting pressure against to keep tension on the fan blades. :frusty:
Jed
Sun, May 2, 2010 2:45 AM
naylorbros
Thank you received: 31
Reply to Jed:
Jed
Jed, I have an extra fan assembley down here somewhere if you want to try it. Let me know.
Ken
Sun, May 2, 2010 8:46 PM
Rd6 plower
Send a private message to Rd6 plower
Reply to naylorbros:
Ken
Does it have the original bearings which is the flat Roller ones if you go to your bearing house and get replacment ones but ball bearings that will queit a lot also guys do it on 60's and 30's.
Sun, May 2, 2010 10:49 PM
