Cat ten transmission bearings
CatMitch
Send a private message to CatMitch
Im trying to put a 1930 cat ten transmission back together and dont have a manual, Im not sure about the direction of the thrust bearings, can anyone help point me in the right direction.
thanks
Sat, Jan 1, 2022 5:56 AM
gauntjoh
Librarian
Thank you received: 8
There is a Cat 10 parts catalog in the members library which should have the information you require.
Sat, Jan 1, 2022 9:33 AM
bruce oz
Thank you received: 23
Reply to gauntjoh:
patrts book dosnt show the bearing in detail , if its open both sides it donst matter which way is goes , ?
Sat, Jan 1, 2022 10:03 AM
CatMitch
The parts books give no direction on the bearings, the direction does matter, there is a 40 degree taper on the thrust side, i was hoping that maybe someone on here had a service manual that could help.
Sat, Jan 1, 2022 1:08 PM
bruce oz
Reply to CatMitch:
answered your own question , old bearing wasn't tapered
Sat, Jan 1, 2022 1:16 PM
CatMitch
Reply to bruce oz:
Makes sense, sometime in the past the transmission must of been rebuilt and they went with all tapered bearings, that is what confused me, Im going to go back with standard radial bearings on the back side of the transmission shaft’s because there is no bearing backstop there therefore no axial load at that point, the bearings are just centered in the case carrying a radial load.
Sun, Jan 2, 2022 2:42 AM
