Cat Ten air filters ?
catrjw
Send a private message to catrjw
Does anybody know if or where I can get the air filter mesh to replace the insides of my air filter for my Cat Ten? Has anybody else used some thing else to replace the rusting metal mesh? As always, thanks for all the help. [email protected]
Mon, Jan 28, 2008 11:52 AM
Pat in WI
Rick,
I pulled all the rusted guts out of mine. I got ahold of some filter material used on paint booths. It is about an inch thick, heavy weave material, but not too dense. I cut out doughnut shaped pieces that fit up into the filter housing. I have 5 of those stacked on top of each other.
Works great in conjuction with the oil bath.
Pat in WI
Mon, Jan 28, 2008 6:13 PM
Jeff M.
Reply to Pat in WI:
Rick,
I cut the inside out and put a dry element in it . It worked great.
Mon, Jan 28, 2008 7:12 PM
MARCOTEN
Reply to Jeff M.:
i put the stuff in to clean pans with a sort of scotch brite
Mon, Jan 28, 2008 11:28 PM
SJ
Send a private message to SJ
Reply to MARCOTEN:
Give this guy a call as he is into collecting antique Cats and does make some parts to sell to rebuild them. He is Geo. Logue and is in Montoursville Pa. at 120 S. Arch St. and the zip is 17754 & His Ph.# is (570) 368-2639 He is located in north central Pa. near Williamsport Pa.
Mon, Jan 28, 2008 11:43 PM
