Cat Sixty steering clutch levers?
Mschwartz
I found another Sixty and I was so focused upon manifolds and engine parts that  I did not realize until later that it has levers like a newer cat not the earlier rotating steering controls. Was this ever an option or a prior owner modification?  Thanks, Mike  [attachment=74292]6D54D54B-E962-476E-8146-39AF6883755D.jpeg[/attachment][attachment=74293]078C9A58-678D-4938-923E-C88E80A8F142.jpeg[/attachment][attachment=74294]98CF56D2-1205-436D-9BD4-205AB88A7002.jpeg[/attachment][attachment=74295]871339DD-3327-428B-B03D-3725EB74E019.jpeg[/attachment]
Sun, Nov 12, 2023 10:15 PM
17AFarmer
Mike. I have seen that straight lever steering set up on a Sixty somewhere down in CA. They must have been a change over kit of some kind 17afarmer
Mon, Nov 13, 2023 2:14 AM
Thank you received: 214
Reply to 17AFarmer:
HI,
Something very interesting in that first picture - maybe Steam?
Question -- why did you choose to put the tie down chains around the frame at the Radiator - scares me thinking a slip of loose chain breaking the tank or core.
CTS
Mon, Nov 13, 2023 5:14 AM
Thank you received: 54
Reply to ctsnowfighter:
HI,
CTS
yep i wouldnt have chained there either. go through the track and chain forwards and to the side on each corner. never shift.
ive seen many excavators and dozers chained by hooking onto a grouser plate and down to the combing rail.
Mon, Nov 13, 2023 10:00 AM
Mschwartz
Reply to trainzkid88:
Yes there is a Case steam engine sharing the shed with the Sixty
Mon, Nov 13, 2023 11:06 AM
Thank you received: 62
Reply to Mschwartz:
The throttle lever ratchet could also be newer. Not familiar with what a 60 would of had. But the one shown is like a RD6. I know the Diesel 35 had something different. More enclosed, so would guess more like other older models..
Tue, Nov 14, 2023 7:09 AM
