cat sixty jugs and valves
Showing 1 to 10 of 12 results
Cat Tracks
Send a private message to Cat Tracks
So I finally got the engine on the sixty torn down now I'm going to need to find a few parts. What I am wondering is can you bore the standard 6.500 jugs out to 6.75 or will the castings get to thin. What i would like to do if possible is find some worn out 6.5 inch bore jugs bore them out to fit my 6.750 inch pistons. If I can't do that I will need to find 3 good 6.750 bore jugs. I will also need to find some valves that are in good enough shape to regrind, also were do you guys find piston rings.
Thanks for all the help
Travis
Fri, Nov 18, 2016 1:38 AM
mog5858
i know my friend that has a sixty bored out to 6 3/4. i can ask him what he started with as he worked it hard for over 6 years with it bore out he also bumped up the compression too. when we tested it this summer it pulled 92HP on the belt.
Fri, Nov 18, 2016 5:01 AM
Jeremy Williams
Send a private message to Jeremy Williams
Reply to mog5858:
Our family has 7 60's and all but one have been bored to 6.75". I believe it was a factory option for them. You can get rings from Otto Engine Works (pistonrings.net).
Jeremy
Fri, Nov 18, 2016 8:20 AM
Cat Tracks
Reply to mog5858:
Thanks mog5858 for the reply
I bet that 92hp sixty really bellowed
Do you happen to know will any casting # jug work to bore out to the 6.75 or is it a certain casting?
Fri, Nov 18, 2016 8:33 AM
Jeremy Williams
Reply to Cat Tracks:
All should work. The ones we have just have less of the taper at the bottom is a fast way to tell.
Fri, Nov 18, 2016 8:44 AM
Cat Tracks
Thanks for the info Jeremy
I thought I had heard that you could get the 6.75 bore from the factory but I wasn't sure if it was a special casting or you just take any jug and bore it out
Thanks again for the info
Fri, Nov 18, 2016 8:45 AM
Cat Tracks
So I just took a look at my jugs they are casting 14A does a parts book show if that is originally a 6.5 inch bore?
Fri, Nov 18, 2016 10:09 AM
rturn3060
Send a private message to rturn3060
The parts books show the cyl. jugs as an assembly number 2475A which includes the head studs. Castings with 14A on them were all 6.5 inch bores. Jugs casting numbers starting 35xx are all 6.75 inch bore that were produced by cat after the 60 production stopped. If you go to the big bore pistons will also have to be located. I have used big bore as well as had 14A jugs re- sleeved standard. The wide rings used on the 60's can often be obtained from hydraulic shops at a reasonable price. Good Luck
Sun, Nov 20, 2016 5:39 AM
Cat Tracks
Reply to rturn3060:
Thanks Russell and everyone else for the good info, I hadn't thought about checking with the hydraulic company's. I will check a few local hydraulic places and see what they might come up with could be cheaper than otto now I need to finish cleaning up my jugs and pistons to see what I will need for sure, so far it is looking like I will need at least one 6.75 jug or I might look for four 6.5 jugs and bore them out to fit my pistons. Thanks again for all the great info
Sun, Nov 20, 2016 8:44 AM
chuckb
OTTO is a good source for rings he has helped me several times a great CAT collector and a very nice and helpful person chuck
Sun, Nov 20, 2016 12:06 PM
mog5858
Reply to chuckb:
well i would say yes she had a good bark to her. have a listen to for your self. he also runing JD D pistons in the 6 3/4 bore but with a little work.
https://youtu.be/UE_YMLHKK9Y
Sun, Nov 20, 2016 10:33 PM
Newby Hall Tractor Fest
