Cat sightings
Cat sightings
Showing 21 to 26 of 26 results
3
Thank you received: 203
Hope they have that D11N tied to the hitching post - sounds like JM is looking to land a big one! Maybe make a tailseat out of it? - cts
Wed, Sep 23, 2026 10:31 PM
Thank you received: 131
Hi, cts.
Make a tailseat outa D11 - Now THAT would be a SEEE-REEE-YUSSS 'rocket launcher'. Wonder if a body could clear the exhaust stacks?
Thu, Sep 24, 2026 12:35 AM
ChrisE
Thank you received: 41
Good luck to JM floating that from Aussie to his house. Probably easier to fix up one of his tail seat machines than fix all the wear in that machine. The owner has a reputation of buying well past worn out machines and putting bandaides on them to keep them going.
Thu, Sep 24, 2026 4:13 AM
ChrisE
The last one was a whopper so here is an example from the other end of the scale
Thu, Sep 24, 2026 12:27 PM
ChrisE
A Cat sighting that is a little different This is a MTS modified Cat articulated tractor matched to a scraper by the Moyners who have the Earthmoving Legacy Centre There were a pair of them working in Geelong in Australia
Sun, Sep 27, 2026 11:27 AM
ChrisE - that crank on the 2-ton looks wicked! I did not like cranking the 2-ton at all.
Sun, Sep 27, 2026 2:03 PM
3
