Cat RD6
Showing 1 to 10 of 154 results
Dieselholic92
Thank you received: 14
I have a Cat RD6 in my tractor collection. The guy who had it before me tried to restore it and didn't do such a great job. The engine hasn't run in about 8 years, the engine is full of diesel, and I heard that when this guy had it running it ran like crap. I'm very familiar with newer and older (maybe 1970s) cat equipment. I don't know where I can get parts for this, if I even can, and I know this is probably far fetched but would the local cat dealership be able to rebuild the motor?
David Gruhot
D & G Excavating, Inc.
Thu, Sep 29, 2011 9:10 PM
Mike Meyer
Thank you received: 6
Tell folks where you are, then you might find there is a good ACMOC Club full of helpful folks just down the road, or suggestions of good Mechanics to work with, or avoid in your area.
They made a lot of that model tractor and many parts are still available off the shelf either new, or good secondhand, it's a matter of you deciding how much of the repairs you can handle, but I wouldn't even think about overhauling that engine till a really good Mechanic investigated the diesel leaking into the motor, as it might only be a $10 seal and a few hours labor to get her running sweet again.
Good luck, they are one of the favorite old Cats of folks here on the Forum.
regards
Mike
Fri, Sep 30, 2011 4:46 AM
catfan
Send a private message to catfan
Reply to Mike Meyer:
regards
Mike
The Altorfer Cat dealer in Hannibal, Missouri (USA) has an excellent used parts department. If you decide to call ask to talk with Bill he is very knowledgeable and must also be a doctor because he has a lot of patients also. The number is 573-221-8600.
Fri, Sep 30, 2011 10:08 AM
Reply to catfan:
I would try talking to the mechanics or "Technician" as the dealership calls them. Alot of those young guys don't know what a Pony Motor is and have a hard time working on something if they can't plug a computer in first. You would be farther ahead following Mike's advice to post your hometown to see if there is an ACMOC neighbor not too far away. Then if you do find an actual equipment engine mechanic to rebuild it, discretely ask if he does work on the side. He will make out better and it will definitely be cheaper for you.
Jeff
Fri, Sep 30, 2011 6:07 PM
gwhdiesel75
Reply to drujinin:
Jeff
We need to know your geographic location in order to suggest parts sources and other Cat collectors.
Fri, Sep 30, 2011 7:59 PM
Dieselholic92
Reply to gwhdiesel75:
There we go, didn't see that I forgot my location in my profile. I'm from Lynd, MN which is right next to Marshall but nobody knows where Lynd is.
David Gruhot
Sat, Oct 1, 2011 12:17 AM
Dieselholic92
Reply to Dieselholic92:
And I might rebuild the engine myself. I've replaced the heads on a D8 14a once. I'm almost positive it needs rings and liners (if they had liners back then?) and probably injectors. It doesn't burn the fuel completely because the exhaust pipe and part of the hood are coated with unburnt diesel. I had the pony motor running but not very well. He cut apart the exhaust manifold on the pony motor and put a flex joint in it so i need a new one of those. And it needs rails and pads. The guy who had it before me made a bunch of blocks and built up the top rollers to take out the slack. I'll try to take some pictures of her later this evening and post them here.
David Gruhot
Sat, Oct 1, 2011 12:24 AM
ronm
Reply to drujinin:
Jeff
[quote="drujinin"]I would try talking to the mechanics or "Technician" as the dealership calls them. Alot of those young guys don't know what a Pony Motor is and have a hard time working on something if they can't plug a computer in first. You would be farther ahead following Mike's advice to post your hometown to see if there is an ACMOC neighbor not too far away. Then if you do find an actual equipment engine mechanic to rebuild it, discretely ask if he does work on the side. He will make out better and it will definitely be cheaper for you.
Jeff[/quote]
I'm guessing you forgot a "not" in there, Jeff? Also, I'd be real careful about asking Cat dealer techs about moonlighting, a guy I know that works at Cat got called on the carpet & severely questioned when he bought a thermostat for a Cat-powered grain truck his dad had borrowed from the neighbor...he seriously thought he was gonna lose his job...they are REAL touchy about moonlighting...although it may be different when it's something like an RD6 that they don't want to mess with anyway...
Sat, Oct 1, 2011 12:42 AM
Mike Meyer
Reply to ronm:
Jeff[/quote]
It might need rings, or it might be like every other old Cat on the Planet that sat around with the main motor idling for hours and just needs to be hooked to a big plow or log and run flat out for a few hours, that cures "slobbering" or that unburnt fuel problem you are talking about. The boys here are spot on about finding an old Mechanic to work on your tractor, avoid the young guys unless they own a couple of old Cats themselves.
I'd suggest you pull the injectors and take them to a good old boys repair shop for testing and cleaning, and while they are out put half a cup of oil into each cylinder to start soaking the piston rings and help seal them up, and pull the rocker cover off and check your valve gaps, and pull the aircleaner base off and check it's not full of water, my RD6 had that problem. Work that main motor hard for a day before tearing it apart is my advice unless your surname is Rockerfeller, Hughes or Hilton.😆
Good luck
Mike
Sat, Oct 1, 2011 3:38 AM
Dieselholic92
Good luck
Mike
Thanks mike, that sounds more like what i want to hear. I am prepared to pull the motor apart in-frame but that isn't really what I want to do. There is a tractor salvage yard about 45 minutes away from here that rebuilds injectors and can test them, or should I take the injectors to Zeigler Cat right here in town? I know a few of the mechanics at Zeiglers pretty well. I still need to figure out why the block is filling up with diesel though. Is there some kind of seal or "seals" on the injector pump that would allow the fuel supply to flow into the block? I have a couple maintenance books for the Cat "RD" series so i'll look for the valve lash specs in there.
David Gruhot
Sat, Oct 1, 2011 4:16 AM
Thank you received: 39
What's the s/n of the tractor?
Sat, Oct 1, 2011 4:50 AM
