Cat PV15 E-Spring Dimensions
OldCat22
Send a private message to OldCat22
My PV 15 had a lot of engine sag in the front before I tore it down for a complete rebuild. I have noticed other PV 15 s that had similar issues. It seems the leaf spring under the engine needs to be re- arched. Anyone know what the specs of the leaf spring should be? I will probably end up taking the springs to a leaf spring shop to get re-arched. At this point I would only be guessing how much arch the spring needs. Any advice? I suppose I could put the engine back in and shim the spring till the tractor is level then use this measurement to get the spring re-arched. It would be nice to have the print or a known good measurement to go off of.
Joe
Mon, Jun 2, 2014 4:28 AM
Captured this off a former post....is this the one your looking for?
Mon, Jun 2, 2014 4:45 AM
OldCat22
Thanks Old Magnet. I believe this will tell me what I need to know. Never fails to amaze me how willing people are to help on this forum. Hopefully I can return the favor one day.
Mon, Jun 2, 2014 5:05 AM
MARCOTEN
Reply to OldCat22:
i put where the spring is in the track cradle a half inch thick piece of strip under the spring( machine looks now horizontal too on the side view), and made a new bushing around the bolt on top of the spring which is holding it so all lack is out of it.
Mon, Jun 2, 2014 5:25 AM
