Cat Power Unit 4D1060
Showing 1 to 10 of 12 results
kellyb
Send a private message to kellyb
I have this engine that is from a Cat 44 pull type grader and it runs!! It is a single cyl. gas engine with a magneto and is air cooled. Its a heavy beast as it weighs 325 lbs.
Does anyone have one of these out there anywhere? Is it rare? I'll try and post a picture or 2 of it.
Tue, Dec 5, 2006 8:31 AM
kellyb
see attachment:
I have a better pic but this site asked me to reduce it to 800 x 1200 so this is the best I can do on short notice.
KB
Tue, Dec 5, 2006 9:18 AM
josh
Thank you received: 13
Book shows the 4d---- as a power unit, used on the 66 and 77 grader.
Tue, Dec 5, 2006 10:12 AM
kellyb
does your book give any specs such as HP, RPM, bore, stroke, etc. ?
also, anything on a governor, carb settings etc. Where can I find this info if not in your book?
Thanks!
Tue, Dec 5, 2006 10:48 AM
bruce oz
Thank you received: 22
Reply to kellyb:
Thanks!
hello kellyb ,the motor fitted to the 44 single frame grader in 1937 was the g800.
bore=3''5/8 stroke= 4'' , hp =5.5 @ 1300 rpm ,sorry this is the only info i have ,hope it helps ,bruce oz
Tue, Dec 5, 2006 12:02 PM
Kelly
Reply to bruce oz:
Kellyb,
Bruce oz, Information is the same as mine. The only thing I would add is at Sn. 4D1196 a further refinement had been made to the grader engine which would assist in preventing the entrance of dirt into the engine. A new cylinder assembly had been provided, which could be used on all graders that completely enclose the valve push rods. Hope this is a little more help. Maybe someone will show up with some more information.
Kelly
Tue, Dec 5, 2006 12:27 PM
gwhdiesel75
Reply to Kelly:
Kellyb,
Kelly
Kellyb, I've been told that the engine is indeed sought after, because it is missing on many of the surviving No. 66 pull graders. GWH
Tue, Dec 5, 2006 9:06 PM
kellyb
Reply to gwhdiesel75:
to gw75 diesel,
I may be interested in selling it, yes, would the best way be to post it on this website?
or ebay it?
KB
Wed, Dec 6, 2006 1:51 AM
naylorbros
Reply to kellyb:
to gw75 diesel,
or ebay it?
KB
Ebay!!!!!!
Wed, Dec 6, 2006 2:37 AM
OzDozer
Reply to naylorbros:
Ebay!!!!!!
The maintenance instructions for the single cylinder G800 engine (the smallest gas engine built by Cat), are found in the Operation and Maintenance Instructions booklet for the Power-Controlled #66 and #77 pull graders.
The OMI form number for the Power Controlled #66 grader, S/N 5E1-up, is 3226 .. and form number for the P.C. #77 grader, 9C1-up is 1663.
Wed, Dec 6, 2006 5:14 AM
OzDozer
Reply to OzDozer:
Bruce - The G800 is listed in the 1936 pull grader catalog as being 8HP, not 5.5HP .. and this catalog lists the #44 and #66 as being the only P.C. grader models available.
Despite the fact that G T Barnards Caterpillar Product Guide book states that the #77 pull grader was built until 1942 .. there is no mention in the comprehensive 1936 pull grader catalog, of the #77 pull grader.
The catalog lists only the #66, #44, #33, and #22 graders, plus the Trailer Patrol grader and terracers.
http://img364.imageshack.us/img364/7798/g800graderenginekq7.jpg
Wed, Dec 6, 2006 5:45 AM
