Cat Paint
Cat Paint
Showing 1 to 10 of 10 results
LeakyBoot
Send a private message to LeakyBoot
Where is a good place to order the old color yellow paint?
Sat, Mar 10, 2018 4:26 AM
Sadly.....not at our Cat dealers! dont that just suck??????????? And John Deere has ALL the paint colors for the there antique tractors!!!!!!!!! hope your viewing this Caterpillar!!!!!!!!!!!!!!!!!!!!
Sat, Mar 10, 2018 5:03 AM
JoeWestfall
Send a private message to JoeWestfall
Try calling Eddy Lucast at KBS coatings
203-228-1961
Sat, Mar 10, 2018 6:07 AM
TOGNOT
Reply to JoeWestfall:
203-228-1961
Maybe depends on how picky you are: I have bought rustoleum CAT yellow through Amazon by the gallon.
I thin it with acetone and add some hardner from tractor supply. Good results.[attachment=47589]image.jpg[/attachment]
Sat, Mar 10, 2018 7:50 AM
LeakyBoot
Reply to TOGNOT:
[quote="TOGNOT"]Maybe depends on how picky you are: I have bought rustoleum CAT yellow through Amazon by the gallon.
I thin it with acetone and add some hardner from tractor supply. Good results.[/quote]
Would that be number 7448402 for the Rustoleum? Thanks. LB
Sat, Mar 10, 2018 9:59 AM
terrywelch_archive
Reply to LeakyBoot:
I got some from NAPA also from my local auto paint store.
Sat, Mar 10, 2018 3:24 PM
TOGNOT
Reply to terrywelch_archive:
It will be a couple of days before I can get the number of the rustoleum paint, but I will post it.
Side note, the instructions said to thin with mineral spirits, and did not specify any hardener. I tried this on some small parts and it seemed like it took a week to dry. Eventually I called rustoleum and they said to thin it with acetone. I told them the can said thin with mineral spirits and he said, "oh, that's the wrong information, thin it with acetone".
Sat, Mar 10, 2018 11:37 PM
Reply to TOGNOT:
They have it in rattle cans also. Rustyoleum that is.
Sat, Mar 10, 2018 11:39 PM
STEPHEN
Reply to TOGNOT:
[quote="TOGNOT"]It will be a couple of days before I can get the number of the rustoleum paint, but I will post it.
Side note, the instructions said to thin with mineral spirits, and did not specify any hardener. I tried this on some small parts and it seemed like it took a week to dry. Eventually I called rustoleum and they said to thin it with acetone. I told them the can said thin with mineral spirits and he said, "oh, that's the wrong information, thin it with acetone".[/quote]
Second on the acetone, whatever rustoleum I was using didn't have any thinning recommendation, called the product adviser & they said acetone. I have used MEK, not sure which one has the higher evaporation. Also used harder, don't know if it helped, didn't seem to hurt. I'm sure the product wasn't designed to use any.
Sun, Mar 11, 2018 12:19 AM
Thank you received: 257
Reply to TOGNOT:
TogNot: that's a "slick" looking d2(pun intended). I've never seen a J with DE. Nice. JM
Sun, Mar 11, 2018 12:30 AM
Thank you received: 46
The Rustoleum "Old Cat Yellow" in gallons is a #7449402. In 12 oz rattle can it's #7449830
You can use paint thinner but it makes drying very slow and voids the low VOC designation and has been replaced by Acetone. It is an alkyd enamel, good rust control by tends to fade.
Here is the thinner options list...
Solvent for Alkyd Enamel (Rustoleum)
Fast dry…..Acetone, Naptha
Medium….Toluene
Slow….Xylene
Very Slow…..Paint Thinner (Stoddard Solvent)
Sun, Mar 11, 2018 1:27 AM
