Hi Oakfan707,
The Bendix is a Cat part No 9B8901 or a delco 1868804, 1915898 there are plenty on Ebay
Regards
Thank you I'll search the numbers. I really appreciate it
The Delco number for the push button starter is a 1107024
Thank you so much. You're knowledge is invaluable. I was able to buy the starter shaft parts i needed right now but found some other parts I'd like to replace while its apart. This will help tremendously in getting the right kit/parts. Thank you again
Be aware of aftermarket parts. Armatures don't have the the shaft pressed to the correct depth. Commutator end plates do not fit properly, brushes can be wrong fit. Only the old NOS filko push button switches fit and work correctly. Field coils are ok. Terminals are ok. Bushings are ok. Be sure to set up end thrust correctly. Look for a commutator end plate that has the bushing upgrade. Early versions ran on the pot metal.
Thank-you so much for the info. I bought an aftermarket part and had no idea about that. I would've been bent hahaha.
Possible Bendix upgrade SDR5022 - think I may have used this on a D6 - will cushion the shock better when using 12 volts
Better to use the early type bendix although most are now imports. Sometimes possible to find a USA built unit but it's the same one used on early flat head fords so most have already been scooped up.
