Cat No 70 Scraper
Cat No 70 Scraper
2HIGHTEN
Send a private message to 2HIGHTEN
i WENT AND LOOKED AT A NICE CAT NO 70 SCRAPER ,
PAN , EARTHMOVER, TODAY rather nice shape ,four good tires and smooth all around. serial no 8c2616 does anyone know how much string it takes to restring one of these machines. I want to put a new cable in this before trying it out. 716-761-6447. Thanks , Ron Meeder
Mon, Apr 14, 2008 8:19 AM
Kelly
Here you go. A page out of the instruction manual. For the Cable Size and lengths on Threading up a 70 scraper, Serial Numbers 8C1001-up.
Kelly
Cat 70 Cable Threading
Mon, Apr 14, 2008 11:03 AM
Kelly
2H,
Here you go. A page out of the instruction manual on the cable Specifications, size and lengths. for the 70 scraper Serial Numbers 8C1001-8C2776. This should work for your scraper with Sn 8C2616.
Kelly
Cable Specification For Cat 70 Scraper
Check Here
Mon, Apr 14, 2008 11:45 AM
tctractors
Reply to Kelly:
2H,
Kelly
Check Here
You do not use a set length of cable, the scraper should have a location front and back for reels to locate min worth-while length to start is about 300ft. this will give you a chance to suffer a few brakes without much waste.
tctractors
Mon, Apr 14, 2008 1:29 PM
