Cat No. 120 motor grader clutch adjustment
Showing 1 to 10 of 10 results
Jamesgang307
Send a private message to Jamesgang307
New member here. I have a Cat 120 motor grader that I picked up at an auction a couple years ago. This past winter while clearing snow drifts, I noticed the clutch slipping. I limped home in low gear. Now I'm ready to hopefully adjust it. It's quite different than any clutch system I've worked on. The manual I have is very basic and I like to know any advice and of any pdf's I can download to get a really good ideal what I'm doing. Also I noticed oil sitting at the bottom inside of the bell housing. Is it a wet clutch system or not?
Sun, May 12, 2019 6:03 AM
nomorejohndeere
Send a private message to nomorejohndeere
I dunno
But does it have a dipstick or fill hole?
another fella just asked a similar question a couple of posts back
Sun, May 12, 2019 6:58 AM
I think the adjustment is carried out by adjusting the release levers on the pressure plate.
In your third picture, the one looking deep into the clutch, you will need to adjust the nut on the link in the TOP of the picture. Roll engine over until you can reach everything conveniently. Pull cotter pin and loosen/adjust castellated nut until there is 3/16" clearance between the face of the throw out bearing and the other end of the release lever. Repeat for the other levers.
I found a small piece of flat iron and drilled a hole in it so I could tie a shoe lace on it to secure it to something outside the clutch housing. Don't want to have to fish it out of the bottom of the clutch if you accidentally drop it!
Caterpillar used the same method of adjusting on the older graders. I had a dry clutch 212 and now have an oil clutch 12E, both adjust the same way.
Looks like the 120 started in 1965, so about has to have an oil clutch. If it doesn't have a dipstick and filler/breather cap, it will use engine oil pumped through it by a section of the engine oil pump for cooling and lubrication.
Sun, May 12, 2019 8:11 AM
kracked1
Go around twice when adjusting the clutch. Otherwise as stated the flat piece of steel or a drill bit work fine for setting finger gap.
Sun, May 12, 2019 6:56 PM
Jamesgang307
Reply to kracked1:
My first few pictures were sideways. This new pic has red arrow pointed towards, I believe clutch plate adjustment and blue arrow pointed towards thurst bearing/plate
Mon, May 13, 2019 12:54 AM
Yes, you got it correct.
Mon, May 13, 2019 3:13 AM
Thank you received: 34
as said by others adjustment procedure should be same as for other earlier oil clutch units.
Note the lanyard attached to the gauge tool--any tools used in this compartment should have a string attached for retrieval in case they are dropped inside the clutch compartment.
As the clutch wears the finger to throw out bearing is clearance is reduced and so needs to be checked periodically--suggest do not wait until the clutch slips as this is when wear takes place--oil clutches usually do not wear fast unless abused or slipped from lack of adjustment.
Hope this helps.
Mon, May 13, 2019 11:03 AM
Jamesgang307
Reply to edb:
Hope this helps.
Interesting. A common brake spoon to gauge with. I was just about to search for flat iron but I will use the brake spoon and check things twice. I did back off the fingers to reset them. They were pressed up against the plate tight. I fear the the worst as for the clutch condition but I'll hope for the best and hope there is no slippage after adjustment.
Tue, May 14, 2019 12:14 AM
Jamesgang307
Reply to Jamesgang307:
I did use the brake spoon to check gaps. Put the 120 back together and took it out for a test run. Made a couple light passes on our road and doesn't seem to slip. Even drove back uphill in 4th gear with no clutch slippage. Tomorrow I'll do some heavier work. Thanks for the tips.
Thu, May 16, 2019 11:41 AM
Hi Jamesgang307,
thank you for getting back to us with welcome news of your apparent success with the clutch adjustment.
We often do not hear back from people after offering help-we always appreciate feed back so we know what helped and what did not in the troubleshooting process and subsequent adjustments etc. so in future we can give definitive help to others in future cases.
Being an oil clutch they can take some abuse with out much harm but there is a limit to the robustness of these units.
Hope the clutch settles in for the long term.
Regards,
Thu, May 16, 2019 1:53 PM
Jamesgang307
Reply to edb:
Hi Jamesgang307,
Regards,
You're welcome and thanks. I hope this subject helps others too.
My blading is on hold for now. Ground is pretty wet.
Sat, May 18, 2019 11:03 PM
