Cat motor grader help
Showing 1 to 9 of 9 results
JSP1234
Send a private message to JSP1234
Hello, could someone help me out on dating and identifying these graders? I can’t find a model number on them and the serial numbers don’t mean anything to me. Thanks for any help.
Sun, Dec 29, 2019 12:18 AM
kracked1
8T was a very popular grader. It was the #12. 12 foot moldboard, 318 engine, the same as D6 8U/9U. 100hp if I remember correctly. Good machine still capable of doing a days work. Yours is very early 1951 model year.
3U was the #112, it used the D315 engine, the same as the D4 7U, 75hp. The 3U series was made from 1947 to 1959. I cant find a by year breakdown.
Sun, Dec 29, 2019 12:25 AM
JSP1234
Reply to kracked1:
[quote="kracked1"]8T was a very popular grader. It was the #12. 12 foot moldboard, 318 engine, the same as D6 8U/9U. 100hp if I remember correctly. Good machine still capable of doing a days work. Yours is very early 1951 model year.
3U was the #112, it used the D315 engine, the same as the D4 7U, 75hp. The 3U series was made from 1947 to 1959. I cant find a by year breakdown.[/quote]
Thank you for the information
Sun, Dec 29, 2019 1:33 AM
JSP1234
Reply to kracked1:
Any idea on what they might be worth?
Sun, Dec 29, 2019 7:32 AM
kracked1
Reply to JSP1234:
Too many variables to tell.
Sun, Dec 29, 2019 8:05 AM
oldbeek
Reply to kracked1:
do the motors run? How many hours on them? Are they all there? Missing pieces? How good are the tires? Check the balls that lift the blade. Are there any shims left on the balll sockets? Answer these questions and we will go from there.
Sun, Dec 29, 2019 11:03 AM
JSP1234
Reply to oldbeek:
I’ll get as much info as I can
Sun, Dec 29, 2019 10:51 PM
Thank you received: 99
Reply to JSP1234:
Hi, JSP1234.
This might help.
http://www.acmoc.org/bb/showthread.php?20409-Cat-12-Graders-Pre-G-series
Sun, Dec 29, 2019 11:26 PM
JSP1234
Reply to kracked1:
Is $1500 each in the ballpark?
Tue, Dec 31, 2019 10:26 PM
kracked1
Reply to JSP1234:
Depends on a lot of things. Do they run? Do they drive? Tires junk? If they have stuck engines and junk tires that is too high. If they run and drive with tires that are good that is cheap.
Thu, Jan 2, 2020 1:15 AM
