cat motor grader 14 e
earthworm
Send a private message to earthworm
looking at buying a 1970 14 e with power shift are they good or bad? do they have any bad things about them? thanks e.w.
Fri, Dec 23, 2011 8:13 AM
rch101
Send a private message to rch101
I operated 14E's in the early 70's. They were a real work horse. Building embankment with tandum axles and a 14 is all you needed.
Fri, Dec 23, 2011 10:44 AM
Thank you received: 137
Reply to rch101:
Hi, Earthworm.
Keep the oils topped up EVERYWHERE and keep them well greased and there are very few more reliable graders anywhere. As RCH101. said, they are a real workhorse.
If it has a rear ripper and no front scarifier, you may want to think about putting some weight out ahead of the front axle in the shape of a push block or something similar 'cos they are a bit light on the steering in that configuration, especially if you want to do much heavy work.
Fri, Dec 23, 2011 12:45 PM
