cat hydraulic hoses
cat hydraulic hoses
squiggle73j
Send a private message to squiggle73j
Hi Guys,
How are Cat hydraulic fittings removed from hoses? are they re-usable? I have a few to change and am unsure how to remove the fittings. Cheers, John
Fri, Dec 9, 2016 4:55 PM
STEPHEN
If they are the old Anchor clam shell two bolt style then just unbolt and do your best to remove the old hose/concrete hard without ruining the barbs. Re-assemble with new hose. Did Cat ever use the re-usable screw on fittings? , Got a pic? No telling what is on an old machine after so many years.
Fri, Dec 9, 2016 5:21 PM
ag-mike
Reply to STEPHEN:
i thought 4 1/4" bolts per fitting. right about seeing a photo.
Fri, Dec 9, 2016 10:11 PM
cheshire cat
Send a private message to cheshire cat
[quote="squiggle73j"]Hi Guys,
How are Cat hydraulic fittings removed from hoses? are they re-usable? I have a few to change and am unsure how to remove the fittings. Cheers, John[/quote] assume these are the clamp type??
I've found the most painless way is heat and burn the outer of the braid the get the wire glowing
and pry and pull it of the barb , or very carefully grind thru the wire without touching the barb , I prefer the heat way , can't beat the smell of burning rubber :flame:
Sat, Dec 10, 2016 4:31 AM
Wombat
Donor
Reply to cheshire cat:
If you are referring to the later type press fittings, the easiest way is to take them to your Cat Dealer (William Adams), they have the special press and tooling to press the fitting apart and fit the new hose and press the outer collar back on.
I know some have gone to a lot of trouble to do it themselves in various ways, I could never be bothered, it all seamed lot of work.
Sat, Dec 10, 2016 5:05 AM
