Cat HT4 Questions
Cat HT4 Questions
Showing 1 to 10 of 11 results
Cat955Hdvr
Send a private message to Cat955Hdvr
Gentleman,
I am going to look at a Cat HT4 for sale in near me in Ohio, I have a couple questions about the tractor before I go.  I've attached a picture of the tractor as well as a few others I found online with similar equipment.
​​​​​​My first question is it looks like the HT4 has dozer mount points on the track frame? Is this common or did someone possibly mount D4 7U frames at some point? I attached some photos of an HT-4 with a blade mounted which was attached to the loader arms.   I don't think the owner has the loader frame, with the previously mentioned mounting points...could I mount a blade if I wanted to?
It also looks like it has the wrong pads on the machine, dozer pads vs loader pads.
does anyone more knowledgeable notice anything? I only have the Trackson Serial, no D4 serial number.  Also, trying to find out if this unit is locked up or just doesn't run...so more to come on that.
thanks for any help,
Nick
Thu, Aug 24, 2023 2:13 AM
Thank you received: 74
My HT4 parts catalog show a bulldozer blade that attached to the loader arms, but it also shows an angledozer attachment that attached at the points you show in your photo, and was raised lowered by linkage to the loader, if I'm interpreting the parts diagram correctly. That could explain the mount in your photo. My buddy has an HT4 and the track frames are bare on the outside so it could very well have supported a Cat 4A/S mounting arrangement too, possibly a tool bar arrangement as well.
Thu, Aug 24, 2023 4:54 AM
It would have a rigid frame though, not very good for a dozer setup.
Thu, Aug 24, 2023 5:01 AM
This would be a better tractor.
https://www.facebook.com/marketplace/item/927950885088955/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A85516981-f8b7-4dcf-8f1d-9840fc503acb
Thu, Aug 24, 2023 8:11 AM
rax200
It has in seat starting and an oil clutch and I would also say 5 roller track frames
Regards
Thu, Aug 24, 2023 11:23 AM
Agreed, I doubt Trackson sold many of them, just not the right tool for the job compared with a purpose-built bulldozer
Thu, Aug 24, 2023 7:30 PM
Thank you received: 59
I picture 3 you can see a clevis welded on the under side of the loader arm as well as bars on the U frame . I am guessing the bars are pined to the arms to lift the dozer blade.
Not that familiar with the 7u and the HT4. Guessing since the same base unit the track frames could be traded back and forth . Probably even the track frames for the heavier undercarriage would bolt on. If they did that in the same time period as the 7u.
Fri, Aug 25, 2023 12:11 AM
Cat955Hdvr
Reply to Ray54:
@Rome K/G - Ya, i'm watching a few including the one you sent me...I wasn't sure if for scap value this one was worth saving for some of the options mentioned (dual circuit hydraulics, 5 roller track frames and a decent looking undercarriage).
@neil - As always, you are a wealth of information. I agree, it's probably was not the best tool for job...just wondering for the money if it's worth saving for any purpose other than parts. I hate seeing old yellow iron go to the torch.
Thanks to everyone else for the feedback
I'll put out an update once I go see it.
Nick
Fri, Aug 25, 2023 1:08 AM
Reply to Cat955Hdvr:
Nick
Ten-4, I could use some parts off of it too but dont need the whole rig.
Fri, Aug 25, 2023 3:53 AM
CATERPILLARHAVEN
Send a private message to CATERPILLARHAVEN
Hi all I have a picture of the blade which Trackson call it AGH4 ANGLEGRADER
I do have the mounting fittings on my ht4 but the blade etc where long gone when I bought the ht4.
Cheers Wayne.
Sun, Aug 27, 2023 7:44 AM
CATERPILLARHAVEN
[attachment=73499]1693097305520674969899273521258.jpg[/attachment]
Sun, Aug 27, 2023 7:49 AM
